Help with finding center caps
Old Oct 27, 2004 | 05:06 AM
MSFITOY's Avatar
MSFITOY
I've been in vain search of a simple 56mm spring steel center-hub cap for my Team Dynamics wheels. Preferably finished in nickle or chrome...hell, at this point I don't care if it's pink plastic I can picture it clearly and have built a simple math model to illustrate. If any of you know where I can find such a thing I'd greatly appreciate it.
Thanks in advance
Old Oct 27, 2004 | 07:34 AM
gr8britwjh's Avatar
gr8britwjh
Looks very much like the centre caps on my BBS CH wheels......not sure about the dimensions though. Maybe Alex at Tire Rack could point you in the direction of something suitable ? I was thinking about something similar to fit a set of Volks....if you find anything generic in various diameters I would be very interested. Good luck.
Old Oct 27, 2004 | 11:03 AM
MSFITOY's Avatar
MSFITOY
I've tried Alex, the net, Discount Tire, etc, etc... I can't believe this simple piece is so hard to find...
Old Oct 27, 2004 | 11:06 AM
kenchan's Avatar
kenchan
Center caps come in all different sizes... do you know if they are
anywhere close to the Rota caps? If so, try http://www.subydude.com/parts/index....eelaccessories
Old Oct 27, 2004 | 11:17 AM
Cynamini's Avatar
Cynamini
Hey MSFITOY! I have the same wheels and I have found that you can attach the MINI stock caps into them by using pvc pipe and epoxy. I have white wheels so I didn't need to paint the pvc. The fit is perfect!
Good Luck on your quest...been there.
-Cyn
Old Oct 27, 2004 | 11:47 AM
MSFITOY's Avatar
MSFITOY
-Cyn
No way Which wheel cap did you use? I thought I checked my Slites a while back and seem to recall they were too large. Can you elaborate on how you mounted yours on? Thanks Pics would be worth a million words...
Old Oct 27, 2004 | 12:08 PM
MSFITOY's Avatar
MSFITOY
I know I need one to fit a 56mm hole in my wheel...I don't know what the Rota caps are as I don't have one to look over.
Old Oct 27, 2004 | 12:14 PM
kazlot's Avatar
kazlot
I just ordered a set of Team Dynamics wheels from these guys and the center caps will be shipped in a few days because they have been on back order They have shipped my wheels minus the center caps.
Team Dynamics Inc.1885 S. VINYARD AVENUE SUITE 4 ONTARIO CA 91761
909 947-0114
Hope this helps...
Old Oct 27, 2004 | 12:16 PM
MSFITOY's Avatar
MSFITOY
909 947-0114
Hope this helps...
I could order them from TD but I'm looking for something simple like my math model above. Still trying...
Update...I found a car with Rotara wheels and the center hub looks to be a little larger than 56mm. I don't know if the hole is small than that or it has a very small flange. If anyone knows, please do tell.
Old Oct 27, 2004 | 08:01 PM
Cynamini's Avatar
Cynamini
Sorry, probably should have mentioned such things. My caps came from my 15" holies and my TDR's are also 15's. At first I just slid the pvc in since the fit was really tight. Turns out that after a few canyon runs they shrink a tad under extreme heat. So I'm going to use some all purpose super strong epoxy (can't remember the brand but it's similar to JB Weld) to secure them in place. Anything is better then those horrid TDR caps! I thought with my chrome valve stems and lugs that the MINI caps looked rather nice.
Ahhh, the wonders of pvc pipe.
I don't have a really good close up picture right now...but I'll try to attach one for some reference.
Good Luck!
-Cyn
Old Oct 28, 2004 | 04:53 AM
MSFITOY's Avatar
MSFITOY
Good Luck!
-Cyn
Thanks very much Cyn for the image. I'll have take a closer look at my Slites and report back
Old Oct 28, 2004 | 05:21 AM
Ozbone's Avatar
Ozbone
I had a set of TDRs on my Passat and I'm pretty sure that I used a chrome plastic centercap purchased from VW which was dished to accomodate a VW emblem backed with adhesive. I strongly suspect other companies also use 56-mm centercaps.
Old Oct 28, 2004 | 07:57 AM
KevinR's Avatar
KevinR
The cap in the model drawing looks a lot like a Mercedes Benz center cap from the '80s. I can't remember the size off hand, but I think I have one at home I can measure.
VW/Audi and BMW E30 center bores are 57.1mm. Some careful filing and fitting of these might do the trick.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
