R56 DDM RIS Pressure Box Seal
Old Feb 19, 2018 | 10:59 AM
ioannes79's Avatar
ioannes79
So I bought a used DDM intake for my car some months back and need ideas about replacing the pressure box seal. I ordered the seal refresh kit from DDM, but the box seal sucks (as you will see in the pics).
Also, I have run into an issue with the intake pushing into the vacuum pump hose barb (?). Do any of you know is anyone makes a different or shorter mount where the vacuum pump attached to the hose?
On a side note, this was totally worth the money I spent. The intake needed some care, so I stripped all parts, painted, and baked a new finish onto it. Heat soak was initially an issue, but I insulated the intake with some heat shielding I found on Amazon. Now my intake temps are usually four to seven degrees above ambient.
Old Feb 19, 2018 | 01:52 PM
BigBoost's Avatar
BigBoost
At less you didn’t spend the 400 bucks on it an find out the hard way hahaha
Old Feb 19, 2018 | 03:39 PM
isamin's Avatar
isamin
I have the same setup on my JCW and had the same problem that I solved by purchasing a leading hood edge gasket from MINI. Check with ECE for this part for a reasonable (cheap) price. Cut to shape and form in place. Much better than original and you'll have plenty of material for other projects.
ISAMIN
Old Feb 19, 2018 | 03:45 PM
BigBoost's Avatar
BigBoost
That's actually a great idea!
I just ended up going with a new intake set up' an cut the scoop out more , more air flow to the hole bay!
Old Feb 19, 2018 | 04:14 PM
ioannes79's Avatar
ioannes79
ISAMIN
I completely overlooked that gasket. :D Sounds like a good idea. Thanks man!
Ladybug-S
Sep 23, 2012 12:41 PM
SsgtThor
Aug 30, 2012 04:54 PM
mellanor
Jan 26, 2010 11:20 AM
killasha
Apr 9, 2009 06:48 PM
Stypica
Sep 26, 2008 08:17 AM
