Navigation & Audio What cable do I need to use Pandora with mini connected?
When I open it on my phone I can see the calendar on my screen but no Pandora . I'm reading you need a special cable (please correct me if I'm wrong). Which would I need for my Android.
No special cable needed if you have a newer MINI - just the Apple USB cable should work fine. If you're using a non-OEM cable, that may be the problem. MINIs are very finicky with 3rd party cables.
Year/Model/Radio Package and which iPhone
If not, then you’re going to get all the newer cars stating “just the iPhone lightning charge cable is needed”
Either you have a pre 2015 model without the Mini Connect or you are asking about Connecting via Bluetooth or the USB/3.5mm Jack to lightning cable or 30 pin
I did not see that before...
In that case, I don't believe MINI Connected for Android supports Pandora or anything else besides calendar. BT Audio or AUX are your only options.
Navigation & Audio MINI Connected & Pandora Issues
Ginvent
11
Apr 5, 2011 05:37 PM
Navigation & Audio Mini Connected - Pandora - iPhone 4 problem
arisoup
Mar 13, 2011 09:24 PM
Navigation & Audio Pandora Iphone App has Update for Mini Connected
VGNCLUB
Jan 27, 2011 08:41 AM
03mini-S
11
Jan 6, 2011 09:23 PM
