R50/53 2005 mini gear ratios
Old Oct 25, 2004 | 12:37 PM
colocraig's Avatar
colocraig
Hello all ...
I'm considering a 2005 MC (coupe, not S model) with 5 speed transmission. Does anyone know the overall top end gear ratio used in the 05s? i.e. - at 60 mph in 5th gear what kind of RPM are you turning?
Thanks!
... Craig
Old Oct 25, 2004 | 01:36 PM
MINIAC's Avatar
MINIAC
Overall gear ratio for 5th is 3.509.
To maintain 60 mph in 5th gear ...
2954 rpm with 175/65-15 tires
2895 rpm with 195/55-16 tires
2917 rpm with 205/45-17 tires
Old Oct 25, 2004 | 02:39 PM
colocraig's Avatar
colocraig
Thanks, Miniac!! Exactly what I wanted to know.
... Craig
Old Oct 25, 2004 | 02:56 PM
ukbyoung's Avatar
ukbyoung
why does it jump back up on 17 tires?
Old Oct 25, 2004 | 06:18 PM
MINIAC's Avatar
MINIAC
RPM required to maintain MPH is effected by tire size ... the larger the tire diameter (hence circumference) the lower the revolutions required to maintain speed. 195/55-16 tires have the largest diameter (24.44") followed by 205/45-17 (24.26") and 175/65-15 (23.96").
Ordering by RPM rather than tire size:
Old Oct 25, 2004 | 06:56 PM
ukbyoung's Avatar
ukbyoung
duh! Im an idiot, I didn't even loot at the other numbers, I assumed they were all the same
B
Old Oct 25, 2004 | 08:27 PM
afromanbob's Avatar
afromanbob
Hmm... very interesting, MINIAC. Could you explain how you computed those numbers, I'd like to figure out some other engine speeds for my own reference...
Old Oct 26, 2004 | 10:49 AM
MINIAC's Avatar
MINIAC
Here's the formula:
R = M / (60 * 3.14159 * (W * P / 100 * 2 / 25.4 + D) / 12 / 5280 / G)
where
R = RPM
M = MPH
W = Width of tire
P = Profile (aspect ratio) of tire
D = Diameter of wheel
G = Gear Ratio
For top speed in gears ...
http://www.mini2.com/forum/faq.php?f...speed_in_gears
iggi
18
Feb 9, 2026 01:00 AM
Toolman
Jan 20, 2016 06:50 AM
mdutton11
14
Oct 26, 2015 01:47 PM
RHcoopers
Aug 6, 2015 07:33 AM
