Interior/Exterior 2006 non heated seat question
Old Jan 7, 2018 | 11:14 AM
ssean72's Avatar
ssean72
I have a 2006 Checkmate, my question is I want to add heated seats to my non heated seats and I have read that some have the elements already installed from the factory. My issue is I can’t find anything showing what the connector looks like. I have four connectors under my seat but they all have plugs connected to them. The connector that looks like the one from the retrofit kit has a pluc connected to it. Does anyone know if my seat has the wiring and the elements pre installed and just need the control panel and a fuse installed, or it doesn’t have the stuff preinstallwd and I need to get a seated seat kit with elements. I have searched all over and can’t find anything that shows what the last two plugs are on my seat.
Attached Thumbnails 2006 non heated seat question-bb2cff74-7d35-4339-849b-ddcf6683c966.jpeg
Old Jan 7, 2018 | 11:44 AM
Whine not Walnuts's Avatar
Whine not Walnuts
There is a recent thread here someplace discussing this matter. I was one that thought the harness would be in place as the fuse block is prepped but I think somebody came back and said you had to buy a separate harness.
Old Jan 7, 2018 | 11:56 AM
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
I think that the heated seat have 2 black connectors. My 2006 drivers seat has yellow, blue, black, and black connectors with last black connector being for heated seat. I retrofitted it and had to buy the wiring kit. No wiring connectors found at the switch. But when I added heated mirrors to the same car it had the 6 pin harness for heated mirrors. Also not sure if it matters, but pretty sure it is a "warm climate" spec car (they list hot and cold climate versions on VIN decoder) as it was delivered in Orlando
Old Jan 7, 2018 | 12:30 PM
ssean72's Avatar
ssean72
Do you have a pic of your connectors since you did the retrofit?
Old Jan 7, 2018 | 12:32 PM
ssean72's Avatar
ssean72
I am good with buying the retrofit kit, just trying to figure out if I have the elements, if not I am going to buy a aftermarket kit
Old Jan 7, 2018 | 03:56 PM
ssean72's Avatar
ssean72
Well from more research looks like I do t have the elements
Old Jan 8, 2018 | 06:12 AM
BoostedBlueToyotas
The kit I bought came with the switch but there is a part number for just the harness. Then you can buy a used switch. Should be cheaper since the kit I bought was $200 from ECS
Old Jan 8, 2018 | 07:20 AM
I dont think you have them in your checkmate, it was dependent on the seat option and if it came with it, its hit or miss on if you have them. I dont see it one yours?
Should look like this:
https://www.northamericanmotoring.co...hey-are-2.html
Also in that link is the install PDF and the kit 61110145996 as well as the little known, 61100152025 cooler seat and 61100152026 hotter seat booster wires. I have the hotter ones in my R52.
Old Jan 8, 2018 | 07:52 AM
ssean72's Avatar
ssean72
Thanks for the info, I did figure out I didn’t have the elements in my seats so I ordered a kit off ebay
Old Jan 8, 2018 | 08:01 AM
Ok, just wanted to make sure.
Old Jan 13, 2018 | 09:38 PM
ssean72's Avatar
ssean72
I did get my aftermarket kit in and installed, turned out pretty well and put the switches in factory location
Attached Thumbnails 2006 non heated seat question-b1da36e1-8196-4c21-8aa3-41670a49b216.jpeg
bratling
Dec 19, 2022 12:11 PM
mini merle
Sep 22, 2015 03:58 PM
mp5999
Aug 26, 2013 06:20 PM
jkling17
May 11, 2008 09:01 PM
ksmaas1
Mar 6, 2007 12:46 PM
