2006 non heated seat question
1 Attachment(s)
I have a 2006 Checkmate, my question is I want to add heated seats to my non heated seats and I have read that some have the elements already installed from the factory. My issue is I can’t find anything showing what the connector looks like. I have four connectors under my seat but they all have plugs connected to them. The connector that looks like the one from the retrofit kit has a pluc connected to it. Does anyone know if my seat has the wiring and the elements pre installed and just need the control panel and a fuse installed, or it doesn’t have the stuff preinstallwd and I need to get a seated seat kit with elements. I have searched all over and can’t find anything that shows what the last two plugs are on my seat.
There is a recent thread here someplace discussing this matter. I was one that thought the harness would be in place as the fuse block is prepped but I think somebody came back and said you had to buy a separate harness.
I think that the heated seat have 2 black connectors. My 2006 drivers seat has yellow, blue, black, and black connectors with last black connector being for heated seat. I retrofitted it and had to buy the wiring kit. No wiring connectors found at the switch. But when I added heated mirrors to the same car it had the 6 pin harness for heated mirrors. Also not sure if it matters, but pretty sure it is a "warm climate" spec car (they list hot and cold climate versions on VIN decoder) as it was delivered in Orlando
Originally Posted by BoostedBlueToyotas
(Post 4358129)
Originally Posted by r53coop
(Post 4358127)
Well from more research looks like I do t have the elements
The kit I bought came with the switch but there is a part number for just the harness. Then you can buy a used switch. Should be cheaper since the kit I bought was $200 from ECS
I dont think you have them in your checkmate, it was dependent on the seat option and if it came with it, its hit or miss on if you have them. I dont see it one yours?
Should look like this: https://www.northamericanmotoring.co...hey-are-2.html Also in that link is the install PDF and the kit 61110145996 as well as the little known, 61100152025 cooler seat and 61100152026 hotter seat booster wires. I have the hotter ones in my R52. https://cimg5.ibsrv.net/gimg/www.nor...bd7c29d8bb.jpg https://cimg3.ibsrv.net/gimg/www.nor...189c4a46c7.jpg |
(Post 4358317)
Ok, just wanted to make sure.
1 Attachment(s)
I did get my aftermarket kit in and installed, turned out pretty well and put the switches in factory location
