Drivetrain Turbo question
Old Nov 15, 2017 | 10:04 PM
Tim Dunbarr's Avatar
Tim Dunbarr
Turbo question
Do you guys have any idea which turbo I'm running here? The guy I bought the car from said it's a ported & polished BW, but I never learned what size. If it helps, it spools up to 21-22 PSI around 3000-ish RPM.
Attached Thumbnails Turbo question-en1.jpg   Turbo question-tb1.jpg   Turbo question-tb2.jpg   Turbo question-tb3.jpg
Old Nov 16, 2017 | 03:21 AM
cerenkov's Avatar
cerenkov
would really need to see the tag and any identification markings. If those aren't available you'd need to measure the diameters of the compressor and turbine wheels for starters.
Old Nov 16, 2017 | 05:36 AM
Yes, the tag looks gone and someone painted it blue on the cool side, looks oem but might have a turbine/fin upgrade.
Old Nov 16, 2017 | 10:12 AM
bugeye1031's Avatar
bugeye1031
Moderator
Just curious...did it come without the heat shield?
Old Nov 16, 2017 | 10:50 AM
yes, i was just thinking that, hopefully you have the heat shield to put back I would not run without it. It will cook the valve cover front and possibly warp out the hood scoop even more.
Old Nov 22, 2017 | 06:46 PM
Tim Dunbarr
Yep, that's exactly how it was when I purchased it. Where's a good place to pick a heat shield up?
Old Nov 25, 2017 | 11:04 AM
Tim Dunbarr
Let me clarify, that's how the turbo was when I purchased the car. I think the guy that installed all the upgrades just failed to put that shield back on.
Old Nov 25, 2017 | 09:15 PM
randeez's Avatar
randeez
check out eurotechs on facebook, I'm almost positive i've seen that on their feed, unless there's several of these running around out there. they should be able to give you an idea of what it is
Old Nov 25, 2017 | 10:25 PM
Tim Dunbarr
HA! Found the comment you were referencing, that's the exact turbo installed in my Clubman! Posted a quick reply to the former owner, should hear back before long. Thanks for the heads up!
Old Nov 27, 2017 | 07:16 AM
randeez's Avatar
randeez
you got it, let us know what you find out, also looks like turbo manifold is coated?
Old Nov 27, 2017 | 11:32 AM
Thats the top factory sheild.
11657595605
https://www.ecstuning.com/Search/Sit...h/11657595605/
https://www.ecstuning.com/b-genuine-mini-parts/hex-bolt/07147543920/
07147543920 x5 is the bolts
Old Dec 6, 2017 | 08:58 PM
Tim Dunbarr
Mystery solved!
So I was finally able to determine it's a stock turbo, just ported and polished.
Old Dec 7, 2017 | 06:56 AM
Thanks for the update.
Yes, from the outside it does look stock except for the blue paint. So that shield should work great.
Old Dec 8, 2017 | 05:05 PM
bugeye1031's Avatar
bugeye1031
Moderator
I have one of WMW's blankets under my stock heat shield....some people just put the blanket on and leave the shield off....you might ask Way for some guidance on that approach. Also, is the lower heat shield missing as well? If I remember correctly, the lower shield is actually two halves, one facing the engine and one facing the radiator. Wonder if the previous owner just left everything off when he reinstalled the turbo after having it ported, polished, and painted..... The lower portion shields the heat from the catalytic convert...I would think that it could be a problem running without it....esp during high ambient temperatures and running slowly, like in traffic.
Old Dec 8, 2017 | 10:49 PM
Tim Dunbarr
Not sure about the lower heatshield bugeye, I'll have to get down there and check it out.
Old Dec 9, 2017 | 07:22 AM
danraabe's Avatar
danraabe
Turbo
Alta has a fabric shield. I. Used it. The factory shield is impossible. I wrapped my down pipe in high heat fabric. It’s hot under there but not impossible to work on the car, and nothing up top melted.
Old Dec 9, 2017 | 09:52 AM
Tim Dunbarr
Is shielding the downpipe necessary if it's catless?
Old Dec 11, 2017 | 02:31 PM
Alta version went nla. I would run a shield or something, still gets hot under there cat or no cat.
Old Dec 11, 2017 | 03:48 PM
danraabe's Avatar
danraabe
Alta no longer available.
They don't have the fabric blanket anymore? That sucks. Using the blanket and the hi-temp wrap is the best. Well you need a shield of some kind and hopefully you left the rear shield bolted to the underside of the engine. You now need something to protect the fan and radiator and something up top.
Keep me informed.
Old Dec 12, 2017 | 11:58 AM
Ok,
There is a universal T3 and T4 tubo blankest you can make fit, but it does not cover everything, scroll to the bottom.
https://www.ecstuning.com/Search/SiteSearch/Turbo_Blanket/
Old Dec 30, 2018 | 08:07 PM
guspi76's Avatar
guspi76
What's the stock boost on these cars? I'm running about 5psi with a 9psi peak between shifts. Thanks
Old Jan 6, 2019 | 10:15 AM
Cesar_lopez's Avatar
Cesar_lopez
if its r56 i think its 12 psi.. correct me if im wrong...
Old Jan 6, 2019 | 05:35 PM
mbwicz's Avatar
mbwicz
Way Motor Works has a fabric heat shield. I have one under the factory shield, but you could also run only this shield. With the proximity of the hot side to the plastic valve cover, you should have some kind of shield on there.
http://waymotorworks.com/wmw-turbo-heat-shield.html
Have fun,
Mike
Old Jan 7, 2019 | 08:27 AM
Boost levels list: https://www.northamericanmotoring.co...r56-boost.html
