Drivetrain R56 boost
Old Mar 8, 2009 | 03:45 PM
mariomllr's Avatar
mariomllr
R56 boost
hi guy s how much boost is the car running stock and thas it hold the boost until red line?
Old Mar 8, 2009 | 04:15 PM
AkFarina's Avatar
AkFarina
i hit a peek of 15 the otherday
Old Mar 8, 2009 | 06:33 PM
richi0207's Avatar
richi0207
I believe its 15 peak boost at stock boost levels.
Old Mar 8, 2009 | 06:39 PM
LONO's Avatar
LONO
My peak has only been about 13.5 psi.
Old Mar 8, 2009 | 06:56 PM
slinger688's Avatar
slinger688
According to the Mini info,
Stock MCS boost is .8 bar which is approx 11.6 psi
JCW stage 1 boost is .9 bar which is approx 13.1 psi
Old Mar 8, 2009 | 08:26 PM
got.pho?'s Avatar
got.pho?
i get 15 all the time. defi gauge. maybe some gauges are ''off''
Old Mar 8, 2009 | 08:30 PM
ScottRiqui's Avatar
ScottRiqui
Do these figures include the "overboost" feature, or does the overboost take it even higher?
Old Mar 8, 2009 | 08:37 PM
slinger688's Avatar
slinger688
Scott, those figures are reported in the Mini literature and Mini writeups including car & driver, road & track etc. I am not sure about overboost which makes these numbers tricky.
Old Mar 8, 2009 | 08:38 PM
Ryephile's Avatar
Ryephile
'07's that haven't been to the dealership for updates will see ~15.5PSIg
'08's will see ~12PSIg
'08 w/ JCW Stage 1's will see ~14PSIg
^^^That's all "Overboost". Normal boost is a paltry 8.5-ish PSIg. YMMV depending on climate and mods.
The MCS's all taper to about 8PSIg at 6500 RPM, whereas the JCW Stage 1 tapers to 9PSIg at redline.
Old Mar 29, 2009 | 07:25 AM
jlevy's Avatar
jlevy
ahhh, so it's not in my head...
I've wondered about this too. I took my 07 to the dealership last year for the installation of the multifunction wheel (it's an early 07 ) and performance was noticeably lower ever after. I'd swear the overboost is no longer there. The lower level of performance definitely reduced the torque steer, but I'd rather have it back .
Any more details on why this was done?
-JL
Old Mar 29, 2009 | 08:34 AM
Ryephile's Avatar
Ryephile
I could only speculate it was to increase the performance gap from Cooper S to JCW models. As it stands now you need to buy the JCW Tuning kit to get back the bulk of the '07 MCS ECU tune. Another possibility is some high-up party pooper found out the MCS puts out significantly more power and torque than advertised and wanted to pull it back to reduce the potential for warranty work. The irony is BMEP has nothing to do with the two main design problems of the Prince engine [HLAs and chain tensioner]. The only backlash is on the grassroots level when guys like us find out MINI lowered the torque output.
Old Mar 31, 2009 | 01:46 PM
minipete07's Avatar
minipete07
Running 15.5psi on overboost on 93 octane...
-16.5psi on overboost on 98 unleaded octane...
Old Apr 2, 2009 | 07:59 PM
MiniPOLACK's Avatar
MiniPOLACK
well...finally after connecting my boost gauge.....im running an un"branded : software..its 15psi...fluctuates to 16-17psi... on stock i/c..tomorrow is d-day with that software, trying to resolve the mystery misfire at 6k rpms....will update tomorrow night..stay in touch
Old May 13, 2009 | 03:24 PM
richi0207's Avatar
richi0207
Hows the tyrolsport intercooler coming along minipolack?
Old May 24, 2011 | 01:33 PM
thefallingtree's Avatar
thefallingtree
2007 MCS with NM Eng Intake mods.
I boost to just under 16.
Idle at -20
upon gas release and slow down -22
easy riding -10
and, not sure if this is obvious, but, i am at about 0 when i hit the gas, and right before the turbo starts spooling
Old May 26, 2011 | 04:28 PM
turtle343's Avatar
turtle343
the 07 seems a lot better than the 08. you get more boost and a LSD
Old May 26, 2011 | 11:28 PM
aaronvb's Avatar
aaronvb
IIRC, the boost pressure can vary based on the atmospheric pressure(altitude), which is why some people see higher boost than others.
Old May 27, 2011 | 01:02 AM
turtle343's Avatar
turtle343
and temp haha
Old May 27, 2011 | 07:55 AM
Bigprfed22's Avatar
Bigprfed22
Old May 28, 2011 | 01:15 AM
robbo mcs's Avatar
robbo mcs
Correct. The car runs off the absolute manifold pressure which is atmospheric pressure + boost. The car will peak at the same manifold pressure under all conditions.
At sea level atmospheric pressure is 14.7psi. With altitude this drops significantly, meaning cars running at altitude will be able to make more boost. This does not mean they are making more power, as the manifold pressure will still be the same.
Likewise, atmospheric pressure can vary quite dramatically if depending on prevailing weather conditions, ie if you are currently having a high pressure or low pressure weather system.
Robbo
rtk90
Aug 29, 2019 09:08 AM
embiggenedmini
Oct 15, 2015 12:36 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
