Navigation & Audio F-56 replacement stereo
Old Sep 29, 2017 | 09:19 AM
Minihector14's Avatar
Minihector14
Looking for a complete system that will fir my 2016 F56 mini Cooper
Navigation and car play
Old Sep 29, 2017 | 09:34 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
There are some Chinese based replacement units, installation seems to be not so simple. Something like this http://www.ebay.com/itm/Android-6-0-...-/112397505625
Good luck, be interested to hear how it works out.
Old Sep 30, 2017 | 08:57 AM
ASKtheteach's Avatar
ASKtheteach
Originally Posted by Minnie.the.Moocher
There are some Chinese based replacement units, installation seems to be not so simple. Something like this http://www.ebay.com/itm/Android-6-0-...-/112397505625 Good luck, be interested to hear how it works out.
This item is for a second gen MINI, not the F series cars.
Old Sep 30, 2017 | 09:03 AM
Minnie.the.Moocher
Go to the website of that manufacturer and you will find an F series version.
Old Jan 25, 2018 | 01:48 PM
jennster's Avatar
jennster
Sorry to butt in but is there not an OEM solution? I'm sure its already been gone over but I am VERY new to the F56 so I am not sure of the terminology to even search for.
Old Jan 26, 2018 | 08:07 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
It's EXPENSIVE to retrofit. My dealer said its probably cheaper to buy a new Mini. Im sure they are being dramatic but I did a rough price out and it was well over $7k to get the OEM nav setup
Old Jan 26, 2018 | 09:17 PM
jennster's Avatar
jennster
Thanks so much for giving any kind of idea. I knew it would really be high but the canned response seems to be it would be cheaper to just buy a new car with those options. I want to ask if they've priced a new car with those options lately! Yes, a bit dramatic indeed.
Old Feb 2, 2018 | 07:04 PM
bratling's Avatar
bratling
Super Moderator
Start trawling eBay. You will need the screen, head unit, touch controller, center instrument trim inserts, possibly center trim between the seat. If it's anything like when I retrofitted the OEM nav into my '09 R55, you may also need to build a few cables by hand.
If you're willing to do a lot of work and figuring it out yourself I suspect you could do the job for under $2000 in parts.
Old Mar 11, 2018 | 12:55 PM
ASKtheteach
Maybe this?
https://www.aliexpress.com/item/For-...c12c8826&tpp=1
Old Apr 3, 2018 | 02:18 AM
tommydh's Avatar
tommydh
I would say to do another aftermarket unit would cost a few thousand in simple fabrication cost and then theres the issue of either losing the info center like most did in 2 gens, or the labor to relocate units and configure them. I may order the Nav unit and hope it comes with RCA outs for amplifiers so I can work from there.
Old Apr 3, 2018 | 04:46 AM
bratling's Avatar
bratling
Super Moderator
if you mean the factory nav unit, it does not. This outfit sells adapter harnesses which you can use to tap into a factory unit without having to cut or splice the factory wiring:
https://technicpnp.com/
Lex2008
How to
Oct 27, 2023 12:05 PM
ajstefanacci
May 10, 2017 06:21 PM
bratling
Dec 2, 2016 02:04 PM
sarom058
Oct 13, 2016 04:51 AM
jbing
21
Jan 2, 2014 07:20 AM
