Navigation & Audio F-56 replacement stereo
Old 09-29-2017, 09:19 AM
Minihector14's Avatar
Minihector14
Minihector14 is offline
Looking for a complete system that will fir my 2016 F56 mini Cooper
Navigation and car play
Old 09-29-2017, 09:34 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
There are some Chinese based replacement units, installation seems to be not so simple. Something like this http://www.ebay.com/itm/Android-6-0-...-/112397505625
Good luck, be interested to hear how it works out.
Old 09-30-2017, 08:57 AM
ASKtheteach's Avatar
ASKtheteach
ASKtheteach is offline
Originally Posted by Minnie.the.Moocher
There are some Chinese based replacement units, installation seems to be not so simple. Something like this http://www.ebay.com/itm/Android-6-0-...-/112397505625 Good luck, be interested to hear how it works out.
This item is for a second gen MINI, not the F series cars.
Old 09-30-2017, 09:03 AM
Minnie.the.Moocher
Go to the website of that manufacturer and you will find an F series version.
Old 01-25-2018, 01:48 PM
jennster's Avatar
jennster
jennster is offline
Sorry to butt in but is there not an OEM solution? I'm sure its already been gone over but I am VERY new to the F56 so I am not sure of the terminology to even search for.
Old 01-26-2018, 08:07 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Mini_Vinnie is offline
Moderator
It's EXPENSIVE to retrofit. My dealer said its probably cheaper to buy a new Mini. Im sure they are being dramatic but I did a rough price out and it was well over $7k to get the OEM nav setup
Old 01-26-2018, 09:17 PM
jennster's Avatar
jennster
jennster is offline
Thanks so much for giving any kind of idea. I knew it would really be high but the canned response seems to be it would be cheaper to just buy a new car with those options. I want to ask if they've priced a new car with those options lately! Yes, a bit dramatic indeed.
Old 02-02-2018, 07:04 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Start trawling eBay. You will need the screen, head unit, touch controller, center instrument trim inserts, possibly center trim between the seat. If it's anything like when I retrofitted the OEM nav into my '09 R55, you may also need to build a few cables by hand.
If you're willing to do a lot of work and figuring it out yourself I suspect you could do the job for under $2000 in parts.
Old 03-11-2018, 12:55 PM
ASKtheteach
Old 04-03-2018, 02:18 AM
tommydh's Avatar
tommydh
tommydh is offline
I would say to do another aftermarket unit would cost a few thousand in simple fabrication cost and then theres the issue of either losing the info center like most did in 2 gens, or the labor to relocate units and configure them. I may order the Nav unit and hope it comes with RCA outs for amplifiers so I can work from there.
Old 04-03-2018, 04:46 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
if you mean the factory nav unit, it does not. This outfit sells adapter harnesses which you can use to tap into a factory unit without having to cut or splice the factory wiring:
https://technicpnp.com/
Lex2008
How to
10-27-2023 12:05 PM
ajstefanacci
05-10-2017 06:21 PM
bratling
12-02-2016 02:04 PM
sarom058
10-13-2016 04:51 AM
jbing
21
01-02-2014 07:20 AM
Quick Reply: Navigation & Audio F-56 replacement stereo
