R57 3rd third brake light replacement
Old Sep 23, 2017 | 12:51 PM
thesilkiest's Avatar
thesilkiest
Can't seem to find too much information on a good place to buy and how to go about replacing it DIY styles. Did a search on this site and on the internet. Not much popped back. $204 at minimania is a no go for me. LOL!
Help please
Old Sep 26, 2017 | 09:18 AM
Brake light is here and its much like the R52 version where you have to take out those rear trims and then there is a small plug.
54342758124
https://www.ecstuning.com/Search/SiteSearch/54342758124/
R57 convertible trim: 54347375319 KT Removel
https://www.northamericanmotoring.co...ding-trim.html
R52 for example:
https://www.northamericanmotoring.co...ng-away-2.html
Old Aug 8, 2020 | 09:04 AM
Doubleugly's Avatar
Doubleugly
I have the same make and model and attempting to remove the 3rd brake light from the connector, any ideas on how to "unplug" it from the LED light assembly?
How to dis-connect the connector from the assembly?
Old Mar 10, 2021 | 11:10 AM
Hello, just came across this, did you ever get it unpluged, should just unclip, might need a little flat head on the side as the clip tab looks broken.
Old Aug 24, 2023 | 07:09 PM
coast's Avatar
coast
I'm in the same boat. The brake light assembly was easy enough to remove from the car, but I cannot detach the cable for the life of me. It's one of the most frustrating things I've ever come across. Why must Minis be so frustrating to work on. What should be an easy task is made 10 times harder by design, I guess. Would be nice if there was a pic a complete plug with the tab that you mentioned was broken off from the pic above. I'm tempted to just crack the assembly to remove the plug. The light's not working anyway.
Old Aug 25, 2023 | 06:47 AM
Yep the clip is frozen in place or broken, i would crack the old light housing and try to save the plug, then get a new light all together.
If you get the plug out, take a picture and i will try to find the end plug.
Old Aug 25, 2023 | 12:58 PM
coast's Avatar
coast
First, thanks for the quick reply. I was able to remove the plug, but I had to use a pick tool to do so. I don't know if the plug will still work for a new light assembly, so I'm hoping that you might be able to help me locate another.
This car is a 2014, but only has 24K miles on it. I don't know how long the LED light assemblies are supposed to last, but maybe it was just time for this one to go. I'd like to test the wiring for power before ordering a new assembly, but the holes in the plug are so small. I'm trying to rig something up for that now. I think I have the model for the assembly itself (89078393 ?), but I don't know about the plug (if there's a part number for that. At any rate, here are the pics:
Old Aug 25, 2023 | 01:29 PM
https://www.ecstuning.com/b-genuine-...t/54342758124/
Thanks, we got one in stock in the red^^ that part has "89078393" on it
This is the closet i could find in 2 pol (pin) repair kit. These also work on the interior lights and door puddle lights.
https://www.ecstuning.com/Search/Sit...h/61132360043/
Do you have a better picture or part numbers on that little black plug on the harness side?
Old Aug 25, 2023 | 01:50 PM
coast's Avatar
coast
I'll see if I can put it under a magnifying glass to see if there's anything imprinted on there. If there is, I'll see if I can get a pic OR a model number. Thanks!
Old Aug 25, 2023 | 02:00 PM
Ok found the plug end, its not in our etk but under tyco, Tyco part is sold to BMW group.
https://www.ebay.co.uk/itm/175001052...=&toolid=10050
Old Aug 25, 2023 | 02:01 PM
coast's Avatar
coast
Here's a pic of the side - looks like a model number - maybe 1-1452577-1? It's hard for me to tell if that's a 4 or 5.
Old Aug 25, 2023 | 03:12 PM
coast's Avatar
coast
Okay - just caught your last message. So if I place the order what kind of ETA can I expect for the light and assembly?
Old Aug 25, 2023 | 03:39 PM
coast's Avatar
coast
No worries - I put the order in for the light assembly. It looks like the plug might take a while to arrive. Maybe the current plug will work until I get the other plug in.
Old Aug 28, 2023 | 07:39 AM
Yep, glad to help. Trying to find that plug in our data but looks likes its not in their.
Old Sep 5, 2023 | 04:13 AM
coast's Avatar
coast
Just wanted to follow up. The brake light arrived on Saturday and I installed it within a few minutes. The old plug works just fine and so does the light - back in business. Thanks.
Old Sep 5, 2023 | 06:24 AM
You are welcome!
Glad to help
Old Nov 22, 2023 | 07:56 AM
wmsue's Avatar
wmsue
Third brake light / backup light R-57 Base
I've got the same problem with my R57 base convertible.
Light bar needs replacing and a new plug needed. I tried to resurrect the old one a few years back when the plug was froze on the terminals. Now it's time to do it again....hopefully the plug is available now?
It's a 4 prong staggered wire plug. I'm also looking for the wiring diagram to install the new plug. Can't find a color coded diagram in the manual.
The light part number is - 63247255925 ....any idea of the part number of the plug and can you order one for me (ECStuning)?
Thanks, Bill
Old Nov 22, 2023 | 09:12 AM
Hello
https://www.ecstuning.com/b-genuine-...138365356~oem/
This this is the one, older version is all black.
Old Nov 22, 2023 | 11:09 AM
wmsue's Avatar
wmsue
Great - Got it in the cart.
Trying again to find the wiring diagram.
Old Nov 22, 2023 | 11:43 AM
Yep, just match the pinout. This helps retain those pins so you can slide them in the new slots. They have tiny little tabs.
https://www.ecstuning.com/b-schwaben...ieces/ce-70-2/
Old Nov 22, 2023 | 11:47 AM
wmsue's Avatar
wmsue
Problem is I don't have the old plug. Just 4 broken off wires.
Bill
Old Nov 22, 2023 | 12:20 PM
https://www.ecstuning.com/b-genuine-...136931880~oem/ x 4
https://www.ecstuning.com/b-genuine-...t/61138353706/ x 4
Then you will need those ^^ Test the plug in the back housing to make sure it fits right, then rewire and insert the new contacts and rubber gaskets.
Old Mar 11, 2025 | 12:33 AM
sgra's Avatar
sgra
For users that had similar issue(or will have) to unplug the third stop lamp(54342758124). Need to push down a small flat screwdriver into the slot(see the arrow on the picture) and gently try to pull connector(2pin plug) out with the screwdriver(this will release the handler/hook - see circled area on the pircture). When you are pulling connector(2pin plug) out with a screwdriver try to pull(at the same time)cables gently too. This should release the connector. Do not rush. In my case it took a some time to release the plug.
Old Mar 11, 2025 | 06:19 AM
Awesome, thanks!
Brian J. Stankis
Aug 23, 2018 08:35 AM
wedge07
Jul 28, 2017 07:00 AM
adrchn
R58 :: Coupé Talk (2012+)
Jul 15, 2016 02:25 PM
Cruzer214
Jul 11, 2016 07:55 AM
burgerdog
R57 :: Cabrio Talk (2009+)
Apr 9, 2012 07:43 PM
