Looking to identify a hose
Old Jul 18, 2017 | 07:07 PM
jbourne's Avatar
jbourne
Hi all,
Can anyone help me identify this hose? The plastic fitting has cracked and I have a vacuum sucking sound from it. I can't find it in RealOEM. It's somehow related to the crankcase vacuum system, but for the life of me, I can't seem to find it.
Any help welcome!​​​​​​​
Old Jul 18, 2017 | 07:34 PM
jbourne's Avatar
jbourne
Actually even more specifically, I need one of the plastic T fittings replaced - so even more than the hose, need the plastic piece ...
Old Jul 18, 2017 | 08:14 PM
oldbrokenwind's Avatar
oldbrokenwind
Is this a hose feeding a cold-weather intake manifold --- one connection at each cylinder?
Old Jul 18, 2017 | 08:42 PM
jbourne's Avatar
jbourne
Hmm. I'm not sure whether it connects to each cylinder or not. That said, it does seem like there are quite a few of those T shape plastic things, so it might ... but what I need the most is the plastic thing apparently, as the hose itself is undamaged.
Old Jul 18, 2017 | 10:46 PM
oldbrokenwind
Take a look at this thread --- https://www.northamericanmotoring.co...ml#post4175817 if this is your manifold, contact the vendor --- he might have the parts you need.
Old Jul 19, 2017 | 06:54 AM
jbourne's Avatar
jbourne
Intake manifold "cold climate version"!!! Damn good sir. You might have just won the Internet. Thanks!
Old Jul 19, 2017 | 10:31 AM
oldbrokenwind
You mentioned RealOEM --- did you use your VIN, or the search options to browse parts? I'd expect the VIN option to have your OEM items shown. Maybe a previous owner changed manifolds?
Old Jul 19, 2017 | 10:47 AM
jbourne's Avatar
jbourne
Interesting question - previous owner had the car for about 8 months and I've owned it ever since, but I wonder if the dealer swapped manifolds at like the 10K km service and didn't even tell the owner? (as the only "unscheduled" maintenance I was aware of was a HPFP replacement at 10K). Alternatively, I suppose it's fathomable my own dealer switched manifolds during say the chain tensioner recall, but unless there was a specific instruction to go to cold climate manifolds, I would almost say the car must've come this way. But indeed, I checked by VIN with RealOEM and got nothing. Odd.
Old Jul 19, 2017 | 03:45 PM
ammodave's Avatar
ammodave
Similar brass and plastic T's are available at most hardware and auto parts stores. Take your old one with you to Ace and Advance Auto Parts ; they may have a suitable replacement.https://shop.advanceautoparts.com/p/...=tee+connector
Old Jul 19, 2017 | 06:05 PM
jbourne's Avatar
jbourne
Ooh interesting. Worth a go, I'll give it a try, thanks!
