R59 How to Remove R59 3rd Brake Light
Old Jul 15, 2017 | 09:43 AM
Meister's Avatar
Meister
I've searched NAM and Google but didn't find specific help on removing the 3rd brake light on an R59 Roadster. I have the plastic panel removed from the boot but can't seem to get the 3rd brake light out. There are 4 sets of clips around the inside edge but I can't get them all depressed at the same time to release the fixture. Any help would be appreciated! Thanks, Mike
Old Jul 15, 2017 | 09:50 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Don't know your car, but http://www.realoem.com/bmw/enUS/show...diagId=63_0633 shows 2 screws.
Old Jul 16, 2017 | 09:45 AM
Meister's Avatar
Meister
Thanks for the link. Mine does not appear to be the same. I cannot see any screws. I am attaching a couple of pictures. One is just a rear shot to reference the Roadster light position. The 3rd light on the Roadster is near the top of the boot/trunk. Very hard to get to from the inside. The second pic is from inside looking from the side at the 3rd light. It is very cramped in there and hard to reach due to the bracing which gets in the way.
Has anyone removed the 3rd brake light from an R59 Roadster specifically? I know the R56 and other models are different.
Attached Thumbnails How to Remove R59 3rd Brake Light-mini-rear.jpg   How to Remove R59 3rd Brake Light-mini-3rd-brake-light.jpg
Old Jul 17, 2017 | 02:59 AM
spiney's Avatar
spiney
I haven't done it myself, but from the picture it looks like you would squeeze the two clips at one end together and gently pop that out a bit, maybe wedging it out with a plastic trim tool on the outside to stop it going back in, then repeat on the other end.
Old Jul 17, 2017 | 10:54 AM
Meister's Avatar
Meister
Thanks spiney. There are 4 sets of clips. I have tried squeezing one set but can't get the fixture to move much - not enough to get a trim tool in. Can't squeeze enough of the clips at the same time. I'll keep playing around with it.
Old Jul 17, 2017 | 11:30 AM
Minnie.the.Moocher
https://www.newtis.info/tisv2/a/en/r...ights/HdO7LmB7
Old Jul 17, 2017 | 12:16 PM
Yea you squeeze the clips, be careful as over time the lens on the r58/R59 seems to loosen up. Mine did this and I replaced it.
https://www.ecstuning.com/b-genuine-...p/63252758940/
Old Jul 17, 2017 | 01:11 PM
Meister's Avatar
Meister
Thank you MtM!
Old Jul 17, 2017 | 07:40 PM
Meister's Avatar
Meister
Was able to get the darn thing out. Pictures were quite helpful. Thank you!
Old Jul 18, 2017 | 10:28 AM
Welcome
Old Sep 2, 2021 | 07:20 PM
bslk1234's Avatar
bslk1234
3rd brake light
I need to replace my light as well. Didn’t know where to go and somebody sent me a link to your thread. Were you ever successful? My first problem is figuring out how to get the liner off of the trunk lid. Then I can tackle getting the light out.
Old Sep 3, 2021 | 07:01 AM
Chris_V's Avatar
Chris_V
The rear liner has two screws near the latch, then the rest of it just pops of with a number of clips around it (it's hard to do without breaking at least one of them, though). Then you can reach the metal clips for the light, and as was mentioned, it's a bit hard to get all the clips. Start at one end and slowly move down the length of the light to get it out.
Old Dec 20, 2021 | 05:24 PM
gresh's Avatar
gresh
I know that you have long since got this fixed, but I had to repace mine and here is how i did it. Since the bulbs are LED and the whole light must be replaced, i took a plastic trim tool and just worked my way around the outside of the housing on the outside until the adhesive was free. Then just pulled it out, bending the clips in the process. they actually didnt bend, but broke free and I was able to put the whole thing back together once it was out (not that I need to). Anyhow, hope this helps someone.
Old May 26, 2023 | 05:09 AM
birdfarmer's Avatar
birdfarmer
I had to replace them on an R58 - it's basically the same.
Take the back trim off (there should be 2 screws holding the trim (4 on an R58) - the only thing left holding the trim are the trim plugs)
Use a big screwdriver to push the bottom clips in one at a time (pushing up the light to hold the clip in). Once you get all 4 of the bottom clips in it basically pushes out.
When you put the new one in - make sure you get those clips secured or it may fall out.
BTW - here is the BMW part - it only fits Coupes (R58) and Roadsters (R59)
https://www.genuinebmwminiparts.com/...mp-63252758940
Iris's mini
R58 :: Coupé Talk (2012+)
Feb 19, 2022 04:15 AM
bslk1234
R59 :: Roadster Talk (2012+)
Sep 2, 2021 06:42 PM
blue al
Feb 2, 2018 12:40 PM
adrchn
Jul 15, 2016 02:25 PM
Kevlars
19
Sep 24, 2014 11:41 AM
