Winter tire choices for the stock 15" rims....
Old Oct 7, 2004 | 08:50 AM
CooperGlenn's Avatar
CooperGlenn
What do you guys recommend?
The choices I can find for this size (175/65R15) are:
Dunlop M2 or M3 Winter Sports
Yokohama Ice Guard
Pirelli Winter 190 Snow Controls
Are all these decent tires for mainly ice and hard packed snow driving?? I will also be driving thru deep snow, but not very much. Thanks.
And should I possibly get some 185/60R15 winter tires because there are more choices, like:
Bridgestone Blizzak WS-50
Toyo Observe GO-2
BFG Winter Slalom
Thanks.
Old Oct 7, 2004 | 09:50 AM
MINIAC's Avatar
MINIAC
Consider 185/65-15 and 195/60-15 also:
http://www.mini2.com/forum/faq.php?f...q_winter_tires
Old Oct 7, 2004 | 10:18 AM
CooperGlenn
Does anyone use a 185/65R15??
Comparing the stock size (608.5mm) to this size (621.5mm) is a 2.1% size change. Is this going to affect the ecu at all??
I can get some Nokian RSis at this size. I just don't want something I can't use....
Old Oct 7, 2004 | 10:35 AM
MINIAC's Avatar
MINIAC
Within ±3% of stock size is acceptable.
Larger wheel diameter is better for snow ... more ground clearance.
MINI2 users with 185/65-15 winter tires ...
Old Oct 7, 2004 | 08:18 PM
kyriian's Avatar
kyriian
me, im running on pirelli winter carving 185/65-15 on steel rims, and they have been flawless all winter last year, and surpised me in the dry too! quieter than the runflats i used to have,
Old Oct 15, 2004 | 05:15 AM
Aqualung's Avatar
Aqualung
1. Not one Michelin Artic in the bunch? Any special reason?
2. Everyone (in MINIAC's posting) is running 185....what's the diff to me 'tween 185 and 195? In the context of snow /dry conditions especially.
Old Oct 15, 2004 | 09:26 AM
Alex@tirerack's Avatar
Alex@tirerack
185 is 1/2 inch narrower, and will cut thru snow better. 195 is wider and will handle better in dry, but bear in mind its a snow tire, so soft compounds will keep yourt from driving too agressivly. These same coumpouds are what yeilds your best snow traction.
Alex
Old Oct 15, 2004 | 11:15 AM
jwardell's Avatar
jwardell
I very very very highly recommend michelin pilot alpins. Unfortunately it looks like they came out with v2 and I don't yet see them available in that size. They should be, I have the v1's in 15's on my other car. Spectacular snow traction and better dry/wet traction than i've seen in most all seasons!
Old Oct 15, 2004 | 12:45 PM
andrew_py_ng's Avatar
andrew_py_ng
I'd recommend Kumho KW17 195/60/15, they are H rated winter performance tire, and is alot cheaper than other name brand tires. I had them on a BMW 325 last year and it performed extremely well.
Kimolaoha
Dec 5, 2020 09:32 PM
FLYM1N1
Oct 13, 2015 04:33 PM
TJANK
Aug 24, 2015 06:11 PM
col127
Aug 21, 2015 02:11 PM
Dashdog
Aug 10, 2015 06:17 AM
