electrical haywire
Old May 3, 2017 | 08:15 AM
lb12's Avatar
lb12
electrical haywire
recently installed new battery on 2012 mini cooper base hardtop. Drove it a few days and now driver side window not rolling up, turn signals not working, dashboard lights off, headlights stay on when starting car even though at off position. please advise
Old May 3, 2017 | 08:18 AM
MiniToBe's Avatar
MiniToBe
it is your FRM module. it is located behind the driver kick panel on the left.
Old May 3, 2017 | 08:22 AM
lb12's Avatar
lb12
Thanks, MTB, for the reply. Will let you know outcome.
Old May 3, 2017 | 08:25 AM
MiniToBe's Avatar
MiniToBe
no problem my friend. one last thought, BE AWARE of DEALER. you can buy one with matching part number and that will get you going. you may find a nearby Mini enthusiast with programming software to reprogram it for you. a small fee may apply
Old Aug 9, 2017 | 10:19 AM
BlackMagicMini's Avatar
BlackMagicMini
What's the outcome. I have similar issues.
Old Aug 9, 2017 | 10:23 AM
MiniToBe's Avatar
MiniToBe
If you have similar issues, i thing you have the same faulty FRM module.
Can you describe your specific case? What works and what doesnt work?
Where u located?
Old Aug 9, 2017 | 03:02 PM
BlackMagicMini
Where u located?
Thanks MiniToBe. Over the last several months have had issues with the + battery cable not being tightened properly to the battery post. Resulted in failed starts and battery warnings. Got that straightened out.
- Recently both windows went down when the hatch was open.
- When closing the windows, they sometimes go back down an inch
- The hatch lock seems to remain open as we try to close the hatch therefore it won't latch
- Flashers turn themselves on when the car is turned off, at the same time the hatch latch won't lock. The flashing is at a higher rate than normal. Hit the flasher button which turned it on, then hit it to turn it off and it stopped the problem.
- Ongoing - issues with not being able to lock/unlock the car using the button on the handle
- Mirrors won't fully open (car is turned on after being parked), sometimes need to close and reopen several times
This seems to be an unusual array of issues. What are your thoughts? Oh, the car is in OR.
Old Aug 9, 2017 | 03:44 PM
MiniToBe's Avatar
MiniToBe
Wow...i dont know where to start.
You have two modules that are acting up:
FRM - lights and windows.
CA (comfort access) - locking unlucking.
I think you need a scanner that cam scan and delete all codes and reintialize the modules.
It is cheaper to invest in a software that does that. I recomment delphi (chinese clone). Read up on it and see what it can do. Also, look for programming SW like inpa, ncs expert and winkfp. If you're not into these things, look for mini enthusiasts in your area who can help.
For the CA, check if the batt needs replacement.
And first and foremost, check agian that the main battery is tight and has good juice.
Finally, do you that little black sensor on the battery negative cable?
Old Aug 9, 2017 | 04:17 PM
BlackMagicMini
Yes, I have the battery sensor, see attached pic. The battery is a good quality AGM, coming up on 3 years old in Nov.
I also remember having the windows do the same - close then open an inch back in 2010 and the dealer reprogrammed the windows, no big deal then. Question now is, is it the same issue or is it tied to the other issues? We'll be checking for any signs of moisture in the cabin. Car has never had any other electrical gremlins so these are new on me.
Old Aug 9, 2017 | 04:19 PM
BlackMagicMini
Sorry, here is the battery pic.
Old Aug 9, 2017 | 05:56 PM
MiniToBe's Avatar
MiniToBe
The dealer did the programming before the batt or after?
Do the windows auto open and close?
Old Aug 9, 2017 | 07:57 PM
BlackMagicMini
I installed the battery almost 3 years ago without any registration and all was fine until recently when the ground cable loosened. The windows open and close then open again about an inch, sometimes.
Old Aug 9, 2017 | 08:03 PM
MiniToBe's Avatar
MiniToBe
Do the windows auto open and close when you use the switch?
schovil69
Apr 14, 2020 10:52 AM
bmies
Mar 27, 2017 10:39 PM
gds194
Mar 15, 2017 08:35 PM
Jeffrey Dwyer II
Mar 4, 2017 09:16 AM
burley
Feb 24, 2017 02:47 PM
