rear light replacing
Old Jan 28, 2017 | 05:43 AM
genik's Avatar
genik
I get a "bulb" indication that there is a "light" issue, and it is, its the left rear light (im attaching a pic). Is there a way i can replace it on my own, and how easy is it to do so?
Old Jan 29, 2017 | 01:27 PM
genik's Avatar
genik
I wonder, isn't there a "how to guide" for replacing the rear lights?
Old Jan 29, 2017 | 08:18 PM
3lusive's Avatar
3lusive
Very easy to do, that same bulb went out on my 08 MCS and I replaced it in about 5 minutes after getting a replacement bulb. In your owner's manual there should be a section on all the different light bulbs used in the car, I found it on page 117 in this PDF:
http://www.miniusa.com/content/dam/m...1107__2008.pdf
You need to buy a replacement W5W bulb. Then open the hatch and take off that felt panel on the left side of the trunk. The light housing is accessible from there and it should be easy to figure out how to take out the old bulb and replace it. That one should be the topmost bulb in the column of 3 (or 4) .
Old Jan 29, 2017 | 08:53 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
pop off the chrome trim and then there is 3 T20 torx screws holding the light in. Pull the light out then you can take the bulb out the back and replace it.
Old Jan 29, 2017 | 11:05 PM
genik's Avatar
genik
Ok i get, thanks guys!
Old Jan 29, 2017 | 11:22 PM
rkw's Avatar
rkw
Why remove the entire light, when bulbs can be replaced through the access panel using no tools?
Old Jan 30, 2017 | 05:59 AM
genik's Avatar
genik
Yes you are right, but when you do this for the first time you dont know whats going on in there behind the light and its easier to dismantle the whole thing. Anyway, yes you are right it can be done without any tools etc.
Old Jan 30, 2017 | 06:38 PM
WayMotorWorks
Vendor
I find it easier to just take the light out. Also we can check the contacts on the bulb sockets easily that way. But your right it can be done without pulling it, but gotta get your hand in the right place.
Old Jan 30, 2017 | 11:36 PM
genik's Avatar
genik
The contacts on the bulb sockets? For what reason check the contacts for, can there be an issue there too?
Old Feb 6, 2017 | 01:32 PM
schatzy62's Avatar
schatzy62
Way Motorworks does a very good job at checking "everything" when they do a repair.
They are checking them for corrosion. Corrosion can cause the lights to do many weird things.
I also check them every time I change a bulb just to be sure.
Old Feb 6, 2017 | 01:36 PM
genik's Avatar
genik
How can i protect them from corrosion?
Old Feb 6, 2017 | 09:12 PM
renchjeep's Avatar
renchjeep
A bit of dielectric grease placed on the contacts should help to eliminate any further corrosion, once any possible previous corrosion is removed.
Old Feb 6, 2017 | 10:58 PM
genik's Avatar
genik
Is corrosion responsible for destroying the metallic wiring?
Old Feb 7, 2017 | 06:23 AM
buzzsaw's Avatar
buzzsaw
Don't touch the bulb with a bare hand. The oil on your hand/fingers may shorten the bulb life.
