Front end shot.. Upgrades?
Old Jan 12, 2017 | 03:44 PM
burley's Avatar
burley
I'm replacing a few front end parts:
-Both front strut mounts
-Left front inner ball joint
-Both front lower control arm bushings
Is this an opportunity to get something better than stock? Are there beefed up aftermarket options or should I stick with dealer parts?
Old Jan 12, 2017 | 08:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
For control arm bushings the Powerflex are the go to must have as they will never wear out again.
https://www.waymotorworks.com/powerf...shing-kit.html
For the strut mounts the only upgrade would a a set of camber plates. If you have stock springs you can use the fixed camber plates as they will give you a little extra camber and are thicker to prevent mushrooming.
https://www.waymotorworks.com/irelan...e-r50-r53.html
For ball joints stock are best
https://www.waymotorworks.com/inner-...0-r52-r53.html
Old Jan 13, 2017 | 05:14 AM
burley's Avatar
burley
Thanks Way! I'll place an order today!
Im also having a valeo SM clutch installed at the same time. Do you recommend anything else getting replaced while I'm in there?
Old Jan 13, 2017 | 07:36 AM
JABowders's Avatar
JABowders
Veteran: Army
Are you replacing your Wheel Hubs and Bearing Carriers as well?
Motor on!
Old Jan 13, 2017 | 07:51 AM
burley's Avatar
burley
Motor on!
Had not planned on it... dont know what those even are, lol. Let me Google it. Are those the same as wheel bearings? If so, I'll just wait for those to fail since labor isn't all that much.
Old Jan 22, 2017 | 09:52 AM
GeneralSpecific's Avatar
GeneralSpecific
I second the PowerFlex bushings. I replaced my girlfriend's suspension components and she really appreciated the improvements.
Old Jan 22, 2017 | 12:12 PM
burley's Avatar
burley
Ordered the power flex. I'm staring at $850 in parts waiting to be installed tomorrow!!
Old Jan 23, 2017 | 06:40 PM
GeneralSpecific
I remember staring down a very similar box of parts. You'll be surprised how much tighter everything is going to feel when you're behind the wheel again.
Old Jan 24, 2017 | 04:13 AM
JABowders's Avatar
JABowders
Veteran: Army
** I really Like your Teardrop Camper **
Motor on!
Old Jan 30, 2017 | 08:23 PM
burley's Avatar
burley
Finally got it back after 8 days in the shop! Replaced the clutch with a Valeo SM, supercharger service, power steering hose, Ireland fixed camber plates, Powerflex bushings, inner ball joints, rear seal, and crank o-ring. Final bill (I supplied all parts and fluids) was $1370.. Less than I expected.
Installed Mini Mania's magnetic bonnet stripes this evening to top off the mechanical work. I'll be biding my time driving 500 miles for the break in period.
First impression of the Valeo is a super light clutch pedal. I knew it would be lighter, but this is feather-light. Not a bad thing exactly, just will take getting used to. No chatter! Engagement feels good.
