Cooper (non S) Modifications specific to the MINI Cooper (R56).
best place to pick up 12v ign live
Old Oct 15, 2016 | 07:14 AM
whitty's Avatar
whitty
Ok so i hate having leads trailed about with a passion so sat nav etc needs to be hard wired in
previous cars I've just picked up a 12v feed from back of fuse box and well thats it simple
but the r56 having can-bus and all this **** i don'f fully understand yet the question is whats the best place to pick up a normal ignition live on an r56 without causing other issues?
thanks in advance for advice
Old Oct 15, 2016 | 10:16 AM
rkw's Avatar
rkw
It's the same as any other car. Use an Add-A-Circuit to tap power from a fuse. Choose a fuse that is switched with the ignition.
https://www.northamericanmotoring.co...not-fuses.html
Old Oct 16, 2016 | 12:15 AM
whitty's Avatar
whitty
ok thank's I've always used a soldering iron and joined to something but the add a circuit seems to be the only way to do it now
Old Nov 1, 2017 | 03:14 PM
medic8206's Avatar
medic8206
When i hard wired my radar detector, I tapped off the 12v for the "cigarette" lighter by the gear shifter/cup holders. Wires can then be fed thru the dash etc, keeping it neat.
Old Oct 20, 2018 | 06:56 PM
Lex2008's Avatar
Lex2008
The green wire on the IBD2 port provides 12 volts with ignition on.
The red and blue wire at the opposite corner is 12 live all volts live all the time.
Th purple wire with white stripe next to the green wire is < 8 volts with ignition on.
Old Oct 20, 2018 | 07:27 PM
S-2013's Avatar
S-2013
Add-a-fuse to a 12v+ switched circuit in the fusebox.. It's how I did my dash cam and probably the easiest method.
Old Oct 20, 2018 | 07:41 PM
Lex2008's Avatar
Lex2008
Easier than pressing a t-connector onto a wire which is right under the dash? I dont think so.
Old Oct 20, 2018 | 08:11 PM
S-2013's Avatar
S-2013
Yeah, easier than that if you can open fusebox.
Ta87
Jun 22, 2021 04:51 PM
13WSCRJCW
Aug 3, 2018 08:08 PM
richardsperry
Aug 31, 2016 11:38 AM
(Keenan)
Aug 13, 2016 04:35 PM
depunz
Aug 10, 2016 03:21 PM
