R56 Advice needed please?
Old Aug 5, 2016 | 01:59 PM
(Keenan)'s Avatar
(Keenan)
I, like so many have fallen victim to the oil supply line going belly up due to heat. I got the kit from detroittuned. My baby girl is up on stands for the last week while I slowly work in it but I've run into a problem. The brace/support that goes against the back half of the down tube heat shield won't budge. I still have the front end on and don't think I have the time, tools, patience, or know-how to remove it. Can anyone please tell me how to get that support to move and what tool or tools you used to get it? Many thanks in advance.
Old Aug 5, 2016 | 02:07 PM
nkfry's Avatar
nkfry
The turbo support stanchion? It should be just a 10mm on the turbo side and a 13mm on the engine block end.
Any pictures of what you are having trouble with?
You can call us at the shop and we'd be glad to walk you through what to do.
586-792-6464
Nick
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Aug 5, 2016 | 02:25 PM
(Keenan)'s Avatar
(Keenan)
It is that part exactly. I can get wrenches on the bolt turbo side (engine side is already off) but I can't get them to turn due to not enough room and/or not enough torque.
Old Aug 5, 2016 | 02:40 PM
nkfry's Avatar
nkfry
We use a long 10mm ratchet wrench, Gearwrench and EZ-Red are a couple of options for the long reach ratchet wrenches, but it takes a bit of oomph to get it to come loose.
Phone:586-792-6464
Old Aug 5, 2016 | 03:25 PM
bugeye1031's Avatar
bugeye1031
Moderator
You should be able to remove the turbo with that brace still attached.....
Old Aug 5, 2016 | 03:49 PM
(Keenan)'s Avatar
(Keenan)
That's a good option but I think with my knowledge and skills that's a second option.
Old Aug 9, 2016 | 01:31 PM
nkfry's Avatar
nkfry
No need to remove the turbo, you're making more work for yourself removing the turbo.
Phone:586-792-6464
Old Aug 13, 2016 | 04:35 PM
(Keenan)'s Avatar
(Keenan)
Update: I did not need to remove the turbo. I did give in and put the car in service mode which is way easier than I thought it would be. Got everything replaced and put back together Wednesday night, took it out for a test and there was an oil leak. So today I pulled it all back apart and I forgot to tighten the banjo fitting to the oil line on the engine side. All is back together again and just got back from a short hard test. All is well. Slight smell from the oil that has been coming out burning off. Everything felt right and sounded right so this should be the last update. I appreciate everyone's help and advice. Gonna get back to motoring!
Eurothrasher
Apr 11, 2021 06:36 PM
lasher10
Apr 23, 2016 12:41 PM
Balloondoggies
R57 :: Cabrio Talk (2009+)
Apr 5, 2016 08:24 AM
speedkills66
Mar 27, 2016 11:34 AM
MiniMe762
Aug 25, 2008 11:41 AM
