R56 Unlock Door with Key
Old Oct 11, 2016 | 06:34 PM
D1QuickSilver's Avatar
D1QuickSilver
This is an embarrassing question for me to ask.
I'm going to remove the main battery to charge it due to the car not being driven currently.
After removing the battery I will need to manually lock the door but I can't seem to have room to twist the key in the chamber.
Any thoughts?
Attached Thumbnails Unlock Door with Key-img_8771.jpg   Unlock Door with Key-img_8772.jpg
Old Oct 11, 2016 | 07:21 PM
gjxj's Avatar
gjxj
aside from your physical "turn the key" difficulty, i'm pretty sure the door key just activates the electric locks so wont work with the battery removed.
Old Oct 12, 2016 | 10:17 PM
rkw's Avatar
rkw
No. It operates the mechanical lock, and this is specifically mentioned in the Owners Manual.
Does the key feel like it inserts farther than it should (like it doesn't "bottom out")? I wondering if the mechanism might be loose or misaligned.
Old Oct 12, 2016 | 10:27 PM
D1QuickSilver
Yeah, it feels like it's in too far.
Old Oct 13, 2016 | 05:29 AM
MiniToBe's Avatar
MiniToBe
i used to close my car with no issues with the battery disconnected. perhaps it is already closed!?
Old Oct 13, 2016 | 09:27 AM
ShipM8's Avatar
ShipM8
I just tested mine out. Mine fits in with about 1/4" left before bottoming out. Turns fine both locking and unlocking.
Old Oct 13, 2016 | 11:15 AM
D1QuickSilver
Very nice, thanks for testing.
So I think I have an issue then
Old Oct 13, 2016 | 03:56 PM
gjxj's Avatar
gjxj
well if you've ever tried it there is no mistaking the electric solenoid sound as you turn the key. There is considerable travel left in the key after the door has unlocked. I suppose that's where it engages the physical lock if there is no electric power.
RiBarrett
Oct 21, 2016 01:22 PM
CraigS
Sep 23, 2016 06:07 AM
MrForgetful
Sep 17, 2016 09:55 PM
GregoryK
Sep 15, 2016 02:52 PM
thomasdmini
Sep 14, 2016 09:22 AM
