F55/F56 LED Upgrades (Not Headlamps)
Old Oct 11, 2016 | 05:00 PM
MINICooper4SFV's Avatar
MINICooper4SFV
Hey all, proud new owner of a Cooper 4DR Hatchback. Love it to death, but would love to upgrade the parking/DRLs and rear turn signals to LED bulbs. Anyone have any experience as such or recommendations for bulbs that are canbus compliant?
Would also love to upgrade the front amber signal lights (I have the white signals). Any advice is appreciated!
(Posting here cause the mods section seems kinda blank on this topic.)
Old Oct 14, 2016 | 07:53 AM
malibujoey's Avatar
malibujoey
Been using JDM Astar off eBay.
Like 12-14 bucks.
They're solid. Be sure you get CANBUS. HAS TO SAY CANBUS OR ERROR
FREE (this site will probably knock down my ALL CAPS )
But you get the point. Also check their vehicle list to make sure it matches. Basically there's one kind for the dome and another for the other lights (map, glove, footwell).
Just ordered for the footwell this morning.
JDM ASTAR 2x T10 Red CANBUS Error Free PX SMD LED License Map Light Bulb 194 168
Item# 231454500924
Old Oct 14, 2016 | 07:55 AM
malibujoey's Avatar
malibujoey
I did order from ECS for the LED first position exterior lights. More expensive. Not sure of my rationale for that. They vouched specifically for that light. Guess it's harder to replace if it's a screwup light so I paid more to make sure it wasn't.
Old Oct 14, 2016 | 03:20 PM
siriuszero's Avatar
siriuszero
I would also recommend CREE bulbs if can find them as well. Much brighter than most out there. The problem is on eBay, a seller may advertise as CREE, but they are not.
Old Apr 30, 2017 | 10:23 PM
lakersguy's Avatar
lakersguy
Is there any type of "list" available that shows what bulb to use in each location?
I E: license plate bulb P5W
Thanks in advance
Old May 2, 2017 | 06:39 PM
WhatV8's Avatar
WhatV8
I know some vendors on here should be able to help (ECS comes to mind), but if you want to venture out on your own, here is a place I have had good luck with:
https://www.superbrightleds.com/
Upgraded all my Mustang's lights to LED's and they work great. No CANBUS on that ride though, but I know SBL has CANBUS compliant listings. I am sure there are good places out on Ebay, but there is just so much junk out there it can make your head spin. Been meaning to upgrade my F54's bulbs to LED at some point here.
Old May 9, 2017 | 09:07 AM
If you do decide with our Ziza LED's they are code free canbus and are here:
Here are all the models so far in the Gen 3 MINI.
https://www.ecstuning.com/News/Mini_F54_F57_Ziza_LED_24034/
Old May 9, 2017 | 10:13 PM
Conrad_Thomaier's Avatar
Conrad_Thomaier
ECSTuning (Sorry, I don't know your name):
Cool stuff!
Why is there a trim removal kit on your list? Is it needed for any light bulb replacement?
Why is the back-up light kit so expensive? Does it include bulbs for the license plate?
Thanks,
Conrad
Old May 10, 2017 | 05:03 AM
Its Mike.
Welcome. We include it as some locations you have to snap out the lens to get to the bulb like the glovebox and trunk light. Also great for removing the trim to access other bulbs.
Backup lights are a pair on most MINIs and they take special bulbs that more focused and very bright. They are priced the same across the board unless the bulb type changes. We also free ship those.
The plate lights on all F56+ MINI are now LED. There are very few thing non LED on the Gen 3+ MINIs. We created kits to cover those and the first I know of for most newer MINIs. No bulb out errors either as we test each one in house also.
Old May 10, 2017 | 08:07 AM
vetsvette's Avatar
vetsvette
Moderator
Hey Mike. Thanks for the info. I have bookmarked the Ziza page and will be ordering a set of the backup lights soon. Have to finish paying for the Dragon trip first.
Old May 15, 2017 | 12:38 AM
hp79's Avatar
hp79
I just put regular cheap $2 led bulbs for my parking lights on my F56. (2 x on front bumper) It used to have a yellowish color old school bulb that didn't match with the factory led headlights.
I want to avoid canbus compatible ones because that'll just waste up energy and heat up the bulb. If I get an error tomorrow I'll try coding it to not check the parking lights.
Old May 15, 2017 | 10:57 AM
Welcome. Yes, the dragon trips are worth it and so much fun.
Old May 16, 2017 | 09:55 AM
hp79's Avatar
hp79
Got it working after esys-coding with non-CANBUS LEDs for my parking lights. I used a cheap LED (probably paid $2 for two T10 wedge type) that I bought couple years ago.
This is for the front parking lights on the front bumper.
BDC_BODY
POL_L_KALTUEBERWACHUNG = nicht_aktiv
POL_L_WARMUEBERWACHUNG = nicht_aktiv
POL_L_IS_LED = aktiv
POL_R_KALTUEBERWACHUNG = nicht_aktiv
POL_R_WARMUEBERWACHUNG = nicht_aktiv
POL_R_IS_LED = aktiv
Again, I don't like using CANBUS compatible LEDs because it'll just waste power and generate unessessary heat. I mean it's just an LED with extra resistors to use up more power.
Old May 31, 2017 | 11:23 PM
hp79's Avatar
hp79
I upgraded my rear parking lights (which also works as extra safety day time running lights) to LED.
LED bulbs were shipped from China couple weeks ago in a loose plastic bag.
It was $1.30 shipped for 4x BA15S P21W 1156 3014 6000K 22SMD bulbs on ebay.
These are non-CANBUS stuff so they don't burn up extra power, but you do need to have your car coded so that the car knows it's not regular bulbs.
I tried replacing the right ones first and didn't see any difference from the regular bulb. I'm satisfied that it uses much less power now because these four bulbs are always on. Attached is before and after photos of the actual part. I won't be replacing the turn signals and reverse light since it's not on most of the time. Maybe if it burns out, I'll replace it with LED since it's so cheap.
The first picture is before the replacement, second is after replacing the bulb. Third picture shows just after replacing the right two bulbs to LED. I didn't take any more pictures after finishing both sides.
Attached Thumbnails LED Upgrades (Not Headlamps)-20170531_162347.jpg   LED Upgrades (Not Headlamps)-20170531_162601.jpg   LED Upgrades (Not Headlamps)-20170531_162807.jpg
Old Jun 2, 2017 | 12:47 PM
xentar's Avatar
xentar
For me, one of my biggest mistake when building the Mini from the dealership was not getting the LED light package.. :(
Just incase anyone here is like me who wants the LED headlamps.. I found a 3rd party headlamps which looks exactly (well almost) the OEM LED headlamps with halo DRLs and projectors
I also changed the bottom DRLs and parking lamps to LEDs.. so far I only got the light error code on the parking lights. Planning to to change the fog lamps to a yellow LED and the rear lights to LEDs as well..
Here's some before and after pics after I got it installed.
Before:
AFTER:
Old Jun 2, 2017 | 01:22 PM
ASKtheteach's Avatar
ASKtheteach
Originally Posted by xentar
For me, one of my biggest mistake when building the Mini from the dealership was not getting the LED light package.. :( Just incase anyone here is like me who wants the LED headlamps.. I found a 3rd party headlamps which looks exactly (well almost) the OEM LED headlamps with halo DRLs and projectors I also changed the bottom DRLs and parking lamps to LEDs.. so far I only got the light error code on the parking lights. Planning to to change the fog lamps to a yellow LED and the rear lights to LEDs as well.. Here's some before and after pics after I got it installed. Before: AFTER:
Where did you get the lights? Are they plug and play? How much?
Old Jun 2, 2017 | 02:13 PM
xentar's Avatar
xentar
I got it from Aliexpress.com and these were shipped to me from China. There's a bunch of these in that site you just need to pick the cheapest one and offers free EMS shipping. I got mine I think around $600 (shipped).
These are indeed plug and play and very easy to install. BUT.. Ok here comes the BUT.. like I said, they are ALMOST the same as OEM ones except with some minor (i guess???) differences.
1. The projectors are using HIDs instead of LEDs.
2. This is probably the one that will make people cringed.. :D
The small logo inside the headlamps.. instead of MINI... it's NIMI.. :D
Other than that, these seem to be a good alternative for those who really wants the projectors with LED halo DRLs.
Old Jun 2, 2017 | 03:44 PM
ASKtheteach
I got it from Aliexpress.com and these were shipped to me from China. There's a bunch of these in that site you just need to pick the cheapest one and offers free EMS shipping. I got mine I think around $600 (shipped). These are indeed plug and play and very easy to install. BUT.. Ok here comes the BUT.. like I said, they are ALMOST the same as OEM ones except with some minor (i guess???) differences. 1. The projectors are using HIDs instead of LEDs. 2. This is probably the one that will make people cringed.. :D The small logo inside the headlamps.. instead of MINI... it's NIMI.. :D Other than that, these seem to be a good alternative for those who really wants the projectors with LED halo DRLs.
Interesting. I see them for $639 with free shipping on the site. I also noticed the backward MINI thing, but I can live with that. What color temp did you go with (what is factory)? I'm surprised that there is no strobing and no coding required,
Since they are apparently Xenon.
Old Jun 2, 2017 | 05:03 PM
xentar's Avatar
xentar
I went for the 6000K 35W Xenons which ares super bright and white.. don't want to get the 8000K since I think it would be more bluish than white.
The LED halo DRLs are also bright even in broad daylight and it doesn't have any flickering or error codes.
Old Jun 4, 2017 | 05:49 PM
mkt3000's Avatar
mkt3000
Can you post a picture of them on?
Old Jun 4, 2017 | 08:08 PM
xentar's Avatar
xentar
Which one? On both the after pics, the LED halo DRLs are already switched on.
Old Jun 4, 2017 | 09:07 PM
malibujoey's Avatar
malibujoey
I got LEDs for the interior from JDM Astar off eBay. They work. Cheap. for R56. Have to be CANBUS
Old Jun 5, 2017 | 10:06 AM
mkt3000's Avatar
mkt3000
Like a nighttime shot of the lights turned on.
Can you post the link to the ones you got? Or PM it?
Old Apr 25, 2020 | 10:19 AM
ausam's Avatar
ausam
Just had installed by a mechanic for $180.
jrosa
Nov 29, 2017 05:43 PM
navybsn
Oct 21, 2016 07:58 AM
Joe C.
Aug 18, 2016 02:30 PM
gfx
R55 :: Clubman Talk (2008+)
Aug 16, 2016 08:14 AM
OutMotoring
Aug 9, 2016 10:33 AM
