Drivetrain battery relocation r56 // meth kit space
So winter is coming fast in northern wisconsin
so mini's going away for the winter
i was thinking for the winter project
about finely installing the meth kit
biggest problem is space right<>
was thinking about putting the battery
in the back like the r53
and put the meth tank and pump ware the battery is
Any one know if the r53 battery
harness
would work for the r56
i knew there's going to be some custom work along with it
but no big deal
just want to pick some peoples brain's
Or any better idea's on the install of the meth ket!
have all winter so no rush
harness
but no big deal
harness
but no big deal
harness
but no big deal
+1 on AquaMist --- go for the HFS-4 --- it's designed for the MCS. No messing with where to put it --- bolts nicely in the trunk, and hose / harness is long enough. His instructions are better than most, and well illustrated. My controller is mounted in the glove box --- a bit trickier to install there, but lots more convenient than any other place, at least for me.
1 gallon vs 2 gallon --- I go thru about one tank of WMI for each tank of gas, and my tank has the "anti-slosh" ping-pong (or swiffer) *****, so there's only about ¾ of a gallon capacity. Makes it easier to remember when to refill the WMI. However, if you do a lot of track time, a 2 gallon capacity might get you thru a whole day --- WMI mix goes pretty quick when you're really on the pedal.
My Manic tuner switched my jet size to 1.0 and the mix from 50 - 50 to 80 - 20. Jeff used to offer any 3 jets from a given range --- I chose the biggest 3 --- 0.8, 0.9, & 1.0. Given your mod list, I'd suggest the same sizes, and work with your tuner to pick the best one.
Whichever system you choose, have fun installing it.
The first three pics in my "garage" show the tank, glovebox, and gauge (the one on top). Here's three more showing the Fast Acting Valve mounted in the battery compartment, a harness "loom" used to protect the wires and hose under the car (not furnished with the kit but highly recommended. I had to repair mine --- it's the harness with tape), and a shot of three wires going to the ECU.
Note the engine is not in the car and things aren't quite where they would normally be. Also, my pics don't show where the harness / hose goes through the chassis / dashboard. I used grommets (also not included in the kit) to keep stuff away from sharp edges. Both looms and grommets are readily available at most hardware stores. The size and quantity will depend on where you choose to route things. ECU wiring will be different if you decide to connect the "fail safe" feature --- mine isn't connected. All wire connectors are included with schematics, pics, and detailed descriptions --- hard to go wrong.
Nope! It's running as designed and adjusted --- flowing just as boost starts. It can be adjusted to start flow almost anywhere in that range. Fail-safe is the only feature I'm not using, and that's because of my aftermarket turbo being manually controlled.
When it flows, how much it flows, and why it flows are all fully adjustable. If you haven't already seen the web site HFS-4 description, I suggest you read it, there's a forum too
http://howertonengineering.com
http://www.aquamist.co.uk/forum2/vbulletin/
Also, product support is awesome --- Jeff helped me recover from a bad batch of methanol that plugged up the system. And that was over three years ago --- been performing fault-free ever since.
Yeh' ill definitely have to do some reading !
What I'm really trying to figure out! Is how does the system knew when to inject the meth! Some kind of sensor ? The few other kits I was looking at was by a vacuum sensor!
If you want to tap into the intake manifold and mount jets, this has been done before. I remember reading about an install that did this. Maybe search the AquaMist forum, or email Jeff Howerton for the required hook-ups.
One dis-advantage to direct porting is you're by-passing the air inlet temp sensor --- the ECU wont compensate for the cooler intake. I don't know what the difference in performance will be. The recommended jet location is "a few to several inches" before this MAP / Temp sensor (not shown in my previous photos).
This is why the system connects to the ECU. I don't recall which signals are tapped, but the system description should mention how it works. One of the adjustments selects between boost and some other parameter --- a variable adjustment, not a switch --- all described in the installation manual.
Ta87
Jun 22, 2021 04:51 PM
TJANK
Jul 31, 2019 06:23 AM
madminii
16
Aug 13, 2016 01:32 PM
TJANK
Aug 10, 2016 11:46 AM
