R50/53 mini r53
Old Oct 5, 2016 | 03:20 PM
lillduff's Avatar
lillduff
mini r53
hi random misfire heres what i have done so far plugs,timing check ok,cam sensor,compression ok,new fuel,new fuel filter,coil and leads,and it still misses what more can i do thanks
Old Oct 5, 2016 | 10:18 PM
Mini Mania's Avatar
R53 misfire
What codes is it throwing?
https://www.northamericanmotoring.co...fire-code.html
Old Oct 6, 2016 | 06:31 AM
lillduff's Avatar
lillduff
hi thanks i don't have a code reader
Old Oct 6, 2016 | 10:14 AM
Saltysalt's Avatar
Saltysalt
how do you know its misfiring?
Old Oct 6, 2016 | 12:00 PM
lillduff's Avatar
lillduff
hi if its not misfiring what could it be
Old Oct 6, 2016 | 12:23 PM
mdaz75's Avatar
mdaz75
If you don't know what the code is how do you know it's misfiring is it running noticeably different if I were you I would first go to auto zone and find out what the code is then go from there they'll read the code for free
Old Oct 6, 2016 | 06:26 PM
lillduff's Avatar
lillduff
please guys trust me its a misfire i just need some help and ideas thanks
Old Oct 6, 2016 | 06:51 PM
HaltCatchFire's Avatar
HaltCatchFire
The "list of things that can cause a misfire" is very long (basically anything that can affect spark, air, fuel, or compression, which is most of the engine). Gotta get the codes to narrow it down.
Otherwise I suggest replacing every part in the car one by one until it goes away
Old Oct 6, 2016 | 07:17 PM
sevin's Avatar
sevin
"Just trust me". That's not how diagnostics work.
Old Oct 6, 2016 | 07:35 PM
lillduff's Avatar
lillduff
hi how did we do it before code readers ?
Old Oct 6, 2016 | 07:36 PM
lillduff's Avatar
lillduff
hi ok maybe i can get one i just hope when i have the codes you guys can help me then
Old Oct 7, 2016 | 05:17 AM
Saltysalt's Avatar
Saltysalt
with the amount of money spent at parts, could have been saved by getting a $40 code reader. most misfires caused in our car is the coil pack. typically post #3 corrodes. you've already replaced that and still getting "misfires". if everything spark related has been changed. clearly its not spark unless your plug gap is like .010''. the code reader will tell you exactly which cylinder is misfiring (if it is at all)
having the code would definitely help in the diagnosis
Old Oct 8, 2016 | 03:15 PM
lillduff's Avatar
lillduff
hi code for 02 sensor #2 could that be it
Old Oct 8, 2016 | 04:29 PM
HaltCatchFire
There are several codes for sensor #2 (the post-cat one). P0138 and P0141 usually mean the sensor is shot. P0136 or P0137 can be a symptom or cause, depending. What is the actual code that was pulled?
Old Oct 10, 2016 | 02:59 PM
lillduff's Avatar
lillduff
hi here are the codes p1242/p0300/p2300/p1109 thanks
Old Oct 10, 2016 | 03:44 PM
HaltCatchFire
None of these are for the O2 sensor...?
P0300 Random Misfire
P1109 Manifold Air Pressure Too High In Deceleration
P1242 Secondary Upstream Manifold Air Pressure Sensor Too High in Deceleration
P2300 Ignition Coil A Pri Ctrl Circ Low
Sounds like your BPV isn't opening and you're boosting when you shouldn't (both the pre and post SC sensors are reading high), running it lean. Check your vacuum connections and IC boots. Check the BPV itself, it might be toast.
Last one says ignition might still be a problem, but tackle the other three first.
Old Oct 11, 2016 | 11:36 AM
Mini Mania's Avatar
R53 BPV Bypass Valve
Here is what the part looks like:
http://new.minimania.com/part/NME760...m-Gen1-R52-r53
User 2224
Mar 19, 2017 12:52 PM
JayDubYa2003
Oct 11, 2016 08:42 AM
MassMini
Oct 6, 2016 01:08 PM
Norvigicus
Oct 3, 2016 08:08 PM
JayDubYa2003
South East - Florida
Oct 1, 2016 03:34 PM
