Not that hot out
Old Oct 5, 2016 | 01:56 PM
Bulydog's Avatar
Bulydog
Not that hot out
I had an A/C hose rub against the oil pan and develop a leak in the A/C hose. I had them replace the hose and make sure it did not rub in the future. Ever since they replaced the hose the outside air temperature shows higher than it really is. I am guessing they moved the outside air temperature sender/sensor to close to the exhaust pipe or manifold. Anyone have an idea where that sender/sensor would be? 2007 drop top, automatic
Old Oct 13, 2016 | 09:34 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Should be in your front bumper on the lower grille. Check its location, the connection and terminals to make sure it's not faulty.
Sensor here if needed - http://www.pelicanparts.com/cgi-bin/...-6-936-953-M36
888.280.7799 | 6am - 5pm PST
Old Oct 13, 2016 | 01:20 PM
Bulydog's Avatar
Bulydog
Thank you for the info. I will check it out. If I need a new one, I also now know where to get it.
Old Oct 13, 2016 | 01:29 PM
ZippyNH's Avatar
ZippyNH
Since it just clips in, it is very easy to forget t snap it into the right spot when potting the car back together after "service mode".
I'm guessing it is touching something....
When they go bad, they typically show -50 if I recall right...and that is pretty darn cold !!
Old Oct 18, 2016 | 11:22 AM
Bulydog's Avatar
Bulydog
Thanks, I haven't had time to look at it, am hoping tonight.
Danscrazyhair
Jun 29, 2020 11:23 AM
evilmini55
Apr 4, 2017 06:25 PM
scarabbrian
Nov 26, 2016 07:35 AM
kingbc
Sep 10, 2016 05:42 AM
miniuy
Sep 5, 2016 06:40 PM
