lower engine mount 03 r53
Old Oct 3, 2016 | 05:11 AM
sherman89's Avatar
sherman89
I have a lower engine mount on a 03 R53 that has the cloth/fiber tye and a plastic the wrap around the center of the rubber mount and and the rear portion of the fiber the wrap has moved up to the top of the mount, to put it back will require force which will probably break the wrap----the rubber mount itself looks good----should the mount be replaced?
Old Oct 3, 2016 | 07:17 AM
nkfry's Avatar
nkfry
Are you speaking of the timing side engine mount?
That strap is mostly there to keep everything together in the event of failure, you can replace the mount if you want, or keep a close eye on it over time and replace the mount when it fails.
Detroit Tuned Engine Mount Early
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Lakehouse
Dec 22, 2019 02:45 PM
rob76turbo
Suspension
Sep 1, 2016 08:24 PM
sootyvrs
Aug 26, 2016 05:35 AM
honderpilot
Aug 19, 2016 04:40 AM
projectslideways
Aug 8, 2016 11:05 AM
