R50/53 Piston ring gap on 05 R53
Old Sep 21, 2016 | 06:17 PM
jeffl's Avatar
jeffl
I'm putting my R53 engine back together and can't fing ring gap spec's. I measured 0.18mm this good or bad?
Old Sep 21, 2016 | 06:21 PM
xsmini's Avatar
xsmini
Little tight.
Nik
Old Sep 21, 2016 | 06:36 PM
jeffl's Avatar
jeffl
Thanks what's the safest way to file the ends
Old Sep 21, 2016 | 06:53 PM
jeffl's Avatar
jeffl
I re measured and was getting .20,.25 ,.20mm
Old Sep 21, 2016 | 06:54 PM
jeffl's Avatar
jeffl
Is there a preference on where the gaps are located on the piston I found them set at 120 degrees
Old Sep 21, 2016 | 07:10 PM
xsmini's Avatar
xsmini
Can't find those specs in the repair manual. Off of memory from mine a few months back. Oil rings spaced at 120°, then the same with the last two. So yes. 120°
Nik
Old Sep 21, 2016 | 07:22 PM
jeffl's Avatar
jeffl
Cool. You ever deal with SPD piston rings? No written directions for install.
Old Sep 21, 2016 | 08:00 PM
jeffl's Avatar
jeffl
Here's another ? How critical is it to replace the main bearing bolts and rod bolts?
Old Sep 21, 2016 | 08:17 PM
xsmini's Avatar
xsmini
No I haven't used those, I went CP. As for rod bolts, I replaced them. It's not recommended to re use them.
Nik
Old Sep 21, 2016 | 08:20 PM
BlwnAway's Avatar
BlwnAway
I would, cheap peace of mind, esp the rod bolts.
Old Sep 21, 2016 | 09:00 PM
jeffl's Avatar
jeffl
Did go with stock bolts
Old Sep 22, 2016 | 09:17 AM
jeffl's Avatar
jeffl
Should I bother with replacing the main bearing bolts?
Old Sep 22, 2016 | 12:16 PM
BlwnAway's Avatar
BlwnAway
While they're not specified a "one time use" like the rod bolts, I would simply because of the amount of time, effort and cost, compared to buying new ones, if one did fail.
Again, another inexpensive way to simply be sure that you did everything you could to avoid problems down the road.
Old Sep 22, 2016 | 01:38 PM
jeffl's Avatar
jeffl
cool. I ordered new rod bolts and just the main bolts not the outer bolts today.
rduffner
Jan 30, 2022 02:58 PM
minime100
Mar 29, 2020 06:19 AM
JBC4317
May 25, 2017 08:04 PM
Mr.pm1982
Sep 15, 2016 03:16 PM
Geoff Boynton
Sep 15, 2016 02:10 PM
