Drivetrain Engine Compatibility
Old Sep 14, 2016 | 07:46 PM
Mr.pm1982's Avatar
Mr.pm1982
I would like to know if the engine block from a 2006 Mini Cooper S is the same engine block as the Mini Cooper 2005?
Old Sep 14, 2016 | 08:21 PM
Fly'n Brick's Avatar
Fly'n Brick
'05 S or justa? The justa has the W10 engine and W11 for the S. The same engine for the '06 and '05.
Old Sep 14, 2016 | 08:39 PM
Mr.pm1982's Avatar
Mr.pm1982
Thanks for your reply. I have a 2005 "justa." So could I take the '05 justa engine block and put it in my 2006 Mini Cooper S to rebuild the engine? Thanks again for your help.
Old Sep 14, 2016 | 11:43 PM
rkw's Avatar
rkw
FWIW, the Justa and S engine blocks have different part numbers, although that doesn't necessarily speak to whether they are "compatible".
http://www.realoem.com/bmw/enUS/show...diagId=11_3081
Old Sep 15, 2016 | 09:36 AM
ZippyNH's Avatar
ZippyNH
the wiring harness and ECU are different....going from a r53 to a r53...that is a cooper S to a cooper S..
the block should be the same...on all r53's....
the 2005+ r53 cars got an updated ecu that had an extra sensor...as opposed to the 2004 r53...
now if you are asking if the r50 and r53 are the same. (cooper to cooper S)....NO
Been covered many times...similar, but NOT INTERCHANGEABLE.
Old Sep 15, 2016 | 09:38 AM
ZippyNH's Avatar
ZippyNH
if i recall right, the machining for the bearings are different...they use different cranks.
Old Sep 15, 2016 | 03:16 PM
Mr.pm1982's Avatar
Mr.pm1982
So it seems like the core (engine block) of the 2005 justa is not compatible with the engine core (referring to the engine block only) of the 2006 Mini Cooper S, correct?
andrewjg1994
Sep 3, 2018 08:16 AM
Jordan94
R60/R61 Stock Problems/Issues
Oct 23, 2016 04:10 PM
ericscottf
Aug 24, 2016 08:03 AM
rockyclm
Aug 21, 2016 06:58 PM
KerMINI06
17
Aug 19, 2016 04:34 PM
