R50/53 Wheel spacer help!
Old Sep 3, 2016 | 03:47 PM
burble_durble's Avatar
burble_durble
Wheel spacer help!
Im thinking of buying some wheel spacers because I think that my stock R90 wheels look really good, but I think they would look a little better with some spacers.
The R90s have these measurements: 17x7 4x100mm 48et.
I have yet to measure the exact length from the tire to the fender flares.
I have looked around, and seen that alot of people suggest 15mm all around.
They claim that they don't cause problems, but I was wondering what you guys suggest.
Whats the thickest spacer to have without rubbing with the R90s?
Old Sep 3, 2016 | 09:44 PM
808R53's Avatar
808R53
I'm running 17x7.5 et.45 w/
215/40/17 tires w 5mm spacers
stock height with no problem of rubbing. So, if you're going to run 205/45or40/17 you should be ok.
Old Sep 3, 2016 | 09:45 PM
burble_durble
Thanks man 👍
Old Sep 3, 2016 | 11:30 PM
RB-MINI's Avatar
RB-MINI
I'm running 12mm spacers on the front and 5mm on the back with R90's and PSS 205/45/17's. The car is lowered with coilovers and I haven't had any rubbing.
The odd spacer sizing is because I needed spacers to clear the spring perch on the front coilovers so I got the 5mm's. I wanted a little more space and you can't get 10mm hub centric spacers for a MINI so I got the 12's and put the 5's on the back.
Old Sep 4, 2016 | 05:32 PM
isamin's Avatar
isamin
At this time you MIGHT consider switching to wheel STUDS and eliminate the problems associated with wheel BOLTS.
ISAMIN
Old Sep 4, 2016 | 07:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With the R90s we've seen just 5mm being fine. Wheel studs work well as they hold the spacers on easier.
https://www.waymotorworks.com/wmw-5m...l-spacers.html
https://www.waymotorworks.com/m12x1....-stud-kit.html
jeffcutler
R57 :: Cabrio Talk (2009+)
Apr 6, 2016 10:36 AM
AlphaQuad
Mar 29, 2016 07:07 PM
thuglife
Tires, Wheels, & Brakes
Mar 16, 2016 06:39 AM
u4ea
Sep 8, 2002 09:20 PM
BLIMEY
Jul 3, 2002 07:26 PM
