New member, just bought 08 mini, clutch problems already
Old Aug 29, 2016 | 11:05 PM
phalanges's Avatar
phalanges
I just picked up a really clean 08 Mini S tonight. I don't even have pictures of it in daylight yet.
I drove it home (about 2 hours) and on the way home I noticed it was making an odd noise. I got it home OK and popped the hood. I immediately noticed the strong smell of burnt clutch (this is not my first manual, I do know how to drive) and my neighbor immediately said it sounded like the throwout bearing needed to be adjusted. I'm used to hydraulic clutches that need no adjustment, so I'm not quite sure what needs to be adjusted, or to be honest, exactly what it was that he said. However, the problem definitely seems to be clutch related.
I bought it from a smog shop in CA (they get cars that won't pass smog, their owners sell them cheap, the shop fixes & flips them) and they just replaced the clutch. Obviously they didn't do something right.
There's no warranty, and even if I did want them to fix it, I'd have to drive it all the way back there and burn the clutch up even more to get there. I'm pretty handy and have done most of my own work, but this is my first Mini.
What should I look at first?
Thanks!
Old Aug 30, 2016 | 06:15 AM
NB Cooper's Avatar
NB Cooper
Typically there isn't any adjustment in a hydraulic actuation system but if it was cable actuated there would be a free-play adjustment. That said, you should have some pedal free-play (movement of the clutch pedal without engagement of the system). This is necessary for proper engagement of the clutch. If this checks out then the only other reason for slippage of the clutch will be inadequate clamping pressure, worn clutch disc or contamination. Unfortunately it will have to be taken apart to investigate these possibilities.
Old Aug 30, 2016 | 07:41 AM
ColoCoug's Avatar
ColoCoug
NB Cooper nailed it. Free play should be your initial focus - is there some or isn't there? In a hydraulic system, that's usually your only clue to how worn the clutch is.
MiniToBe's Avatar
MiniToBe
could is be your front breaks? how did you pin point the issue to the clutch other than the smell? how many miles on the car?
Old Aug 30, 2016 | 08:37 AM
phalanges's Avatar
phalanges
The clutch is new. It was just installed by the shop. I don't think it was done right.
I checked the pedal and while there's resistance all the way at the top, it doesn't get noticeably harder to push the pedal until about 2" in.
106,000 miles.
So do I have a hydraulic or a cable actuated clutch?
It's not the brakes. I forgot to mention the noise that I heard.
Old Aug 30, 2016 | 08:42 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
its hydro there is a slave and its' tied to the brake fluid. I would start with bleeding the slave again
they might have gone cheap and just tossed a clutch in without a regrind or replaced flywheel
Old Aug 30, 2016 | 08:58 AM
NB Cooper's Avatar
NB Cooper
This would be my guess as well. They may have even simply replaced the disc and not the pressure plate or the flywheel, who knows. The problem is access to verify the shortcoming.
So let's toss out a few "what ifs" (assuming that the clutch was done right)
What if the master cylinder isn't being allowed to return to the fully released position or what if the system is holding pressure because the return port in the master cylinder is blocked? This would result in a reduction of the clamping force on the clutch disc because the throw out bearing would still be applying pressure on the pressure plate fingers. Simply cracking the bleed screw would relieve the pressure but the issue would return as soon as you pumped the clutch. Sitting static there should be no pressure in the hydraulic system so if you did find pressure there, it would indicate a problem with the master cylinder or a rigging issue between the clutch pedal and the master cylinder.
It's a bit of a stretch but I've seen it on brakes before so it may be worth a look.
Old Aug 30, 2016 | 09:08 AM
phalanges's Avatar
phalanges
He said he replaced the flywheel as well.
Old Aug 30, 2016 | 09:10 AM
phalanges's Avatar
phalanges
I have too, but I can't really tie any of that to the noise in the video.
Old Aug 30, 2016 | 09:37 AM
MiniToBe's Avatar
MiniToBe
how about the transmission fluid. is it verified that it is at the right level. can you take another video from the bottom, towards the tranny housing? also, if you rev the engine up a little, what happens to the noise?
Old Aug 30, 2016 | 09:56 AM
NB Cooper's Avatar
NB Cooper
That noise is nasty!
It sounds like the release bearing about to explode.
If you did have a blockage causing pressure in the system, it would hold the release bearing engaged with the pressure plate and cause it to wear out really fast. It would be just like riding the clutch all the time and it would also cause the clutch to slip.
Old Aug 30, 2016 | 10:04 AM
phalanges's Avatar
phalanges
How do I check the fluid? I don't see a dipstick for it.
I need to run to the parts store today to pick up a pair of ramps for it so I can get under it. What are you hoping to learn?
The noise becomes more frequent and worse when it's revved. When I was looking at the car to buy it on Sunday, I took it on about a 15 minute drive and there were no noises or smells. Now the noise starts almost as soon as I start it up.
This car is very strange to me. I don't even see any belts or accessories on the front of the motor. Are they tucked away under there or is there some new-school way of charging batteries and running water pumps?
Old Aug 30, 2016 | 10:21 AM
NB Cooper's Avatar
NB Cooper
The single drive belt is on the passenger side of the vehicle well out of sight. It drives the AC and the alternator.
Old Aug 30, 2016 | 10:45 AM
MiniToBe's Avatar
MiniToBe
there isnt a dipstick. it is an "enclosed" system. there should be a plug next to the long axle.
I want to see if the fluid is low and maybe the gears are grinding or something of that nature. I dont know how they replaced the clutch, but when i did mine, i drained the tranny and removed the axles. pulled the engine out and did the work outside.
the other members could be right about about the release bearing
one belt on the left side of the engine (standing in front of it).
Old Aug 30, 2016 | 11:14 AM
phalanges's Avatar
phalanges
That makes sense.
When I left, I got right on the freeway and did 70 to 75 for over an hour. I live about 7 or 8 miles off the freeway and there are about 6 or 7 red lights. I hit a few and noticed the sound when I was stopped. I was almost home so I popped the hood as soon as I got there and smelled the burnt clutch.
I guess one of the cylinders needs to be replaced. This would probably explain why the clutch needed to replaced to begin with. 106,000 miles is very much on a clutch.
Old Aug 30, 2016 | 11:17 AM
NB Cooper's Avatar
NB Cooper
Picture is worth a thousand words.
Old Aug 30, 2016 | 11:26 AM
NB Cooper's Avatar
NB Cooper
The more I listen to that sound bite, the more it sounds like a starter bendix that isn't properly retracted. It's almost too rough to be the release bearing.
Old Aug 30, 2016 | 11:57 AM
phalanges's Avatar
phalanges
You know... that's a really good thought. It would be obvious when I pull the starter off, right?
Does that explain the smell? Or are there two problems?
Old Aug 30, 2016 | 12:15 PM
MrBlah's Avatar
MrBlah
turns the starter into a generator don't it? lol I bet it gets real hot
Old Sep 7, 2016 | 04:31 AM
NB Cooper's Avatar
NB Cooper
So a week has passed and I would love to know if you had a chance to dig into this. Whassup??
Old Sep 13, 2016 | 04:41 PM
phalanges's Avatar
phalanges
Sorry! I finally got the car back the other day and I've been having too much fun driving the darn thing!
They replaced the throwout bearing. I don't know they installed (or received) the wrong part or whether it was defective, but the car seems fine now.
Now I noticed an oil consumption problem but that's another thread.
Thanks for the help!
quickcoop
Dec 4, 2020 09:05 AM
solomio
Oct 19, 2018 11:12 AM
808R53
Detailing 101
Mar 18, 2016 04:49 AM
MiniSkoon
Mar 14, 2016 12:45 PM
FSU_MINI_LOVER
May 31, 2002 08:21 AM
