Help with video
Old Aug 14, 2016 | 04:36 PM
chav's Avatar
chav
Help with video
My 2009 mini is going this but only under full throttle and high rpm turn headphones up.
Old Aug 14, 2016 | 07:20 PM
oldbrokenwind's Avatar
oldbrokenwind
Find out what code it's throwing and maybe we can help.
Old Aug 14, 2016 | 08:26 PM
chav's Avatar
chav
The Codes are for O2 ( catless downpipe ) and then on a Walmart $20 scanner P0320 most of the time the check engine light for limp mode goes away right away or sometimes just flashes.
Old Aug 14, 2016 | 09:55 PM
oldbrokenwind
????? Sorry.
Old Aug 17, 2016 | 02:56 PM
chav's Avatar
chav
????? Sorry.
So Today I was able to clear all the codes do a pull and let it cut out again and give me the limp mode. I scanned the car and it came up with no codes. so I decided to do another pull with in limp mode and it still was cutting out just like the video. I recently replaced spark plugs with NGK 1422 and spaced to .022 and new ignition coils and a new intake hose. My car is all stock expect for a catless down pipe. I do know I have a small exhaust leak where the down pipe and jcw exhaust meet but I have always had that and nobody can seem to fix that. I thought it might be my high pressure fuel pump so I don't think so.
Old Aug 17, 2016 | 03:27 PM
oldbrokenwind
NGK1422's should be gapped at 0.024" (6mm). Note that these are one range colder than OEM and typically need a few more mods than just catless downpipe. You might want to talk with a tuner to get rid of your limp mode issues --- catless DP's are pretty common for them. Are your new coils OEM or aftermarket?
Old Aug 17, 2016 | 07:13 PM
chav's Avatar
chav
Okay I will take a closer look at the gap and they are Delphi ( https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ) I will order stock plugs and see if that changes anything.
Old Aug 17, 2016 | 07:48 PM
oldbrokenwind
I read somewhere that OEM coils are designed for iridium plugs. Are you sure this is an OEM replacement coil, for your model / year? Amazon description doesn't mention Mini. If still available, maybe try your original coils?
Old Aug 18, 2016 | 09:38 AM
chav's Avatar
chav
My car did the same thing on stock coils that's why I replaced them as it was time for new spark plugs anyway. I just thought it was bad plugs, bad coils that made the problem.
thelawson
Mar 29, 2016 09:45 AM
thelawson
Mar 25, 2016 06:02 PM
lasher10
Mar 23, 2016 08:01 AM
Sfiveten
Oct 29, 2003 02:27 PM
