Drivetrain Manic Tune & Sprint Booster
one has nothing to do with the other. sprint booster is only affecting throttle response and doing nothing tune wise. if you feel like you want more throttle response without having to mash the pedal down, then go for it.
Good point, the Sprint Booster gets rid of the dreaded throttle lag, or that hopeless feeling you get when you want to jump out into traffic, hit the throttle, and not a lot immediately happens. Some good testimonials here if you are interested:
http://new.minimania.com/Sprint_Boos...eviews_Part_II
What year and model do you have? This is for Gen 2 but we have them for all versions:
http://new.minimania.com/part/SPR209...61-F55-F56-F54
The reason I asked is that I have a Manic 2+ tune. It replaced a JCW tune and the throttle response going to the Manic tune seemed improved - so I figured that the tune was the cause of this. We kind of hoping MarioCart would have responded on this... Anyway, I guess the only way to find out (since anyone that has done both have not responded) is to buy it and find out. I don't know if the relative high cost of doing so is worth it or not. That's my delimma.
Sprint Booster
30-day guarantee.
http://new.minimania.com/So__what_is_a_Sprint_Booster
mQubed Motorsport, Manic Tuning Dealer
What happens if you run the SB at Green with sport button off?
30-day guarantee.
I would bet that having both the SB and a aftermarket tune will cause an engine malfunction especially if you went wide open throttle.
it's not like the quicker throttle response will add more power over the tune.
You will probably get a CEL (check engine light) running both under boost and it could go into limp mode.
You do know the sprint booster only changes the throttle mapping right? A throttle map (sensitivity) has nothing to do with actual engine power. All the SB is doing is giving you a higher throttle position than the actual pedal travel. Meaning when you press down 10%, you get 50% throttle. Whereas stock would be 1 to 1 (with a slight delay). There's no difference in having a SB with or without a tune. A SB gives you NO additional power. If someone says their SB makes their car faster, it doesn't. It just feels faster because you get 100% throttle quicker.
Sprint Booster
Here's how the Sprint Booster works, and why so many of our customers are big fans:
http://new.minimania.com/SPRINT_BOOSTER___Why_it_works
Also, here's a handy FAQ:
http://new.minimania.com/SPRINT_BOOSTER_FAQ_S
30-day money back guaranteed. Hope this helps!
