Navigation & Audio R56 Bluetooth - Why No Bluetooth Audio?
Old Jul 31, 2016 | 10:22 AM
Tortie's Avatar
Tortie
When I press Siri (iPhone 6S), it comes through Bluetooth. Same with maps. Why can't I push audio through as well? (Instead of having to plug into the y-cable?)
Thank you in advance!
Old Jul 31, 2016 | 12:31 PM
rkw's Avatar
rkw
In the R56 (and other 2nd gen models), Bluetooth streaming audio is only available if you have MINI Connected.
There have been threads about working around it:
https://www.northamericanmotoring.co...connected.html
https://www.northamericanmotoring.co...r-adapter.html
Old Aug 2, 2016 | 05:43 AM
Tortie's Avatar
Tortie
Thank you for the links. I discovered the Bluetooth y cable and may just try it.
Old Aug 2, 2016 | 08:54 AM
3lusive's Avatar
3lusive
That's probably the best option. I went with a bluetooth to aux-in device, also around $20, but had to purchase a ground loop isolator to eliminate a high-pitched whine in the audio for $10. the y-cable adapter is likely more functional and you might be able to use the steering wheel controls too.
ryanvar42
R60/R61 Stock Problems/Issues
12
Apr 23, 2017 02:26 PM
ceddy1031
Jul 29, 2016 06:16 PM
Smitha6
Jul 20, 2016 06:08 AM
sukonthorn
Jul 13, 2016 07:12 AM
sbninja
Jul 8, 2016 03:55 PM
