Illegible radio display
Old Jul 29, 2016 | 10:47 AM
DianaUT06's Avatar
DianaUT06
Turned on my 2013 Mini Coop S this morning and this is what my radio display looks like! Any thoughts on what could be wrong? Anything I can try to fix it or am I looking at an expensive trip to the dealer?
Old Jul 29, 2016 | 10:49 AM
ZippyNH's Avatar
ZippyNH
Pretty sure something is "broke" when a display looks like that....bet the fix will be a new/different unit.
Sure a dealer can do it....but the better Indy shops can likely do the swap too for less.
Old Jul 29, 2016 | 10:57 AM
miniuy's Avatar
miniuy
it was suddenly or after something?
Old Jul 29, 2016 | 10:59 AM
DianaUT06's Avatar
DianaUT06
Suddenly. Car recently had maintenance 2-3 weeks ago. No major problems.
Old Jul 29, 2016 | 11:14 AM
MCS4FUN's Avatar
MCS4FUN
Hopefully, you still have remaining warranty in play on that 2013 MCS. Mine, which originally went into service as leased vehicle May 2013, would be covered on such an apparent failure. That, plus additional warranty year being purchased as CPO 2 months ago (a major consideration at price point vs older with higher mileage).
Good luck and please let us know the outcome...
Old Jul 29, 2016 | 11:15 AM
Flyinace2000's Avatar
Flyinace2000
Not sure it will help but maybe disconnect the battery for a bit and see if it clears?
Old Aug 4, 2016 | 06:22 AM
miniuy's Avatar
miniuy
Try to disconnect the battery for 30 min and check the radio display
Old Jan 26, 2018 | 11:49 AM
JCDM's Avatar
JCDM
Did you figure this out? Having the same issue
Hi,
I'm having the same issue with my radio display. Did you fix it disconnecting the battery? Thanks.
Old Jan 26, 2018 | 02:28 PM
DianaUT06's Avatar
DianaUT06
Originally Posted by JCDM
Hi,
Yes it did fix it!
Old Jan 29, 2018 | 12:11 PM
Thats good, I have never seen it do that, so it was a connection error or computer error. Most of the time when i see a messed up display its this:
Where the dot matrix on the screen starts to fade like an older BMW display.
https://www.northamericanmotoring.co...appearing.html
Old Dec 26, 2018 | 10:41 AM
lamalberto's Avatar
lamalberto
I have the same display problem and fixed by disconnecting the battery for 30 minutes. It really safe my day. The dealer asked for $1700 to replace the radio unit.
Old Dec 27, 2018 | 08:30 AM
Yep, i had the same issue on my old R56 and it was worse in the heat of the day. Had to replace the screen, no battery disconnect fixed mine :(
Bludevilx
Dec 20, 2018 01:29 PM
Mar 24, 2016 11:31 AM
cooperScaleb05
Mar 13, 2016 08:00 PM
disillusiondsoul
11
May 20, 2002 08:40 PM
tf
Apr 5, 2002 06:41 PM
