Dealer charging for recall?
Old Jun 30, 2016 | 06:29 PM
miniguy2144's Avatar
miniguy2144
Hello!
My car is up for Recall Campaign No. 15V-660: Electro-Hydraulic Power Steering (EHPS) System
My local dealer made a prompt appointment and provided me with a loaner vehicle to perform this recall repair. I appreciate that.
They have informed me that in order to perform the recall on my car, the following charges are necessary:
Nearly $200 for power steering flush
Nearly $600 for power steering hoses
I am told that there are two hoses that are leaking that are not part of the recall, as well as the fluid flush.
The recall bulletin specifically states that "If your MINI dealer is unable to remedy the defect without charge or within a reasonable period of time, you may notify the Administrator, National Highway Traffic Safety Administration....."
Can a dealer require payment to fix something that would be related to components in a recall? (this seems iffy.... and the bulletin language seems very clearcut)
Can the dealer force a charge of a fluid flush for a recall? (I'm pretty sure this is a big fat NO)
Thoughts?
Old Jun 30, 2016 | 07:17 PM
ZippyNH's Avatar
ZippyNH
If hoses are bad....yes you need them....but a new system needing a flush?! Sounds like a bit of an issue...
Yes...it sounds like the prices ARE inflated a bit...lots actually.
Old Jun 30, 2016 | 07:37 PM
miniguy2144
Yeah... I expect to pay a premium going to the dealer, but this seems like a bald-faced ripoff.
I'm going to contact mini HQ and see what their take on the situation is and go from there. It is an interesting issue, the recall notice states pretty clearly that recall work must be done free of charge, and leaves no room for necessary repairs outside the scope of the recall. Certainly not for a mandatory fluid flush (since they're replacing the parts... what are they flushing?!).
I was seriously considering getting this car fixed up respectably, selling it and getting an all4, I may yet, but definitely not from this place...
Old Jun 30, 2016 | 07:59 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
You can do that work yourself or at another mechanic and then go back for the recall. Makes sense that they aren't going to do a recall repair if you have leaks.
Old Jun 30, 2016 | 10:03 PM
Shawnnn's Avatar
Shawnnn
Do the lines yourself. $130
https://www.ecstuning.com/News/MINI_...006_2007_2008/
Or you can do what one person did and harass the hell out of the dealer and Mini until you get the work done for free. Might not work for everyone though.
Screw the flush, no way you should have to pay for new fluid.
Old Jul 1, 2016 | 06:11 AM
Yep: DIY here and other kit options 32416781744 KT
https://www.northamericanmotoring.co...hose-pics.html
Another updated DIY
https://www.northamericanmotoring.co...placement.html
Old Jul 1, 2016 | 06:58 AM
Fly'n Brick's Avatar
Fly'n Brick
Made me go look. PS hoses were replaced 12 of 13 at 80K miles. Total cost by an independent was $320. The dealer sounds like a rip off artist.
Old Jul 1, 2016 | 09:40 AM
cristo's Avatar
cristo
Alliance Member
My dealer charged me about $430 to redo the hoses associated with the recall
and pump replacement (after quoting me $300 beforehand). They didn't charge specifically for a fluid flush, though.
Old Jul 1, 2016 | 12:17 PM
jgk6502's Avatar
jgk6502
Independent shop around here wanted $518 for power steering hose replacement. I think they have a 10% off labor coupon on their website.
Old Jul 6, 2016 | 01:49 PM
minhi's Avatar
minhi
FWIW
when i went in for my PS recall they also quoted about the same for the hoses replacement (i argued because seemed high since they already had the car apart) i declined and they just re-connected the hoses. keep in mind that one of the reasons the hoses 'fail' is that the clamps go bad, so just by replacing the ps pump they have to replace the clamps and that might fix your issue.
i see two options: if they insist that they cannot do the recall without replacing the hoses, then fire back at them that it sounds like that should be included since the recall is supposed to cover everything it takes to fix it. likely this will get them to back off and they will have you sign something that says you declined the hoses and you'll need to keep an eye on it and possibly get it replaced aftermarket.
as far as charging for the ps flush, don't they have to take the fluid out to replace the pump? sounds like it should be included to me.
Old Jul 6, 2016 | 11:25 PM
Filmy's Avatar
Filmy
When MINI did my pump replacement, they also did the fan and the fluid - no charge to me. They didn't mention any leaky hoses, though they did mention other wear items that needed replacing so I know they checked around. At least one of my hoses is now leaking (based on what another Mini mechanic said) so I'm changing them both out when I drop my sub-frame this weekend. Odd that the dealer would overlook an opportunity to replace the P/S hoses if they could.
Anyway, yeah the fluid should be part of the repair. Sounds like a ripoff to me.
Old Jul 7, 2016 | 04:19 AM
MVPeters's Avatar
MVPeters
I'd like to see one of these so-called "leaking" hoses.
I have a feeling it's just the O rings in the connections, which have to be removed anyway to change the pump.
When my PS recall was done, I had the same story - "If we don't change the hose, the new pump warranty will be void". It seems to me that if the hose was really leaking, it would contribute to the pump failure. In my case the hose was certainly "damp", but no loss of fluid or drips on the garage floor after 2 years. I wish I'd thought of this at the time & saved $350.
I think it's a way for the dealer to get paid twice for the same job - once by Mini for the recall pump & fan & again by the customer for the "hose".
Old Jul 7, 2016 | 08:16 AM
cristo's Avatar
cristo
Alliance Member
Sounds like I got hosed by those hosers that work at the MINI service dept.
fixthedoor
Apr 15, 2019 08:00 AM
2001f4s
Apr 29, 2016 05:42 AM
mkochjr
Apr 13, 2016 02:09 PM
MothAudio
Apr 3, 2016 06:34 PM
Nick Royer
Apr 3, 2016 01:39 PM
