R50/53 Chrono Pack Retrofit
Hi. Does anyone know or has anyone ever heard of someone successfully retrofitting a Chrono Pack into an R53 that currently has NAV? I had heard or read that it is not possible unless you change out most of the receiving car's electronics or ignition, or something like that. Possibly to do with the odometer.
Any help or 'rumors' would be appreciated. Especially if documented!
Thanks,
Lee
Thanks,
Lee
Talked about here going from chrono to nav.
https://www.northamericanmotoring.co...-nav-pack.html
Chrono Pack retrofit
https://www.northamericanmotoring.co...-retrofit.html
https://www.northamericanmotoring.co...rono-pack.html
Just give up...the parts are NLA
ALL 3 clusters must be replaced and vin coded and the miles entered...
And only some ECU's...the 2005 (yes, the computer were not exactly the same for all 6 years)...
It's been said before...if it is a must have, get a different car.
While not impossible to complete, it does end up costing a lot of time and money. Even if you buy used clusters and programming tools, it's still going to run at least $500.
It is true that the ECU's aren't completely compatible with all of the module versions though.
Thanks for the correction!!
The reality is, aftermarket guages can be you 100% of the info in the chrono kit...even better...
The coolant temp is trivial to add, and the oil psi is pretty easy...
The oil temp is not a "real" value, but a generated value based on the water temp...there is no sensor...that having been said, it us pretty accurate based on a few folks that did add real guages...
Heck a scanguage II mounted on a nice craven-speed mount has more info for much less $$.
I had a car with the chrono pack for 10 years ...I did like it. But having read of more than one failed swaps, I'd say live without it if the car didn't have it...some folks got most of it to work...but had the wrong warning lights light up....usually a VIN# and/or mile mismatch warnings..sounds like there are tools to program this on a used part now, but an extra $$....good luck...
Thanks for all of your input, guys. I do realize it will cost but having no gauges at all with the NAV is VERY frustrating, especially doing track events! Also, there is not much room to add aftermarket gauges, so I am willing to try it.
Also, I do realize that I have to watch for the model year variation in the used units that are offered for sale. I hope to have a NAV unit up for sale before too long!
GodSpeed,
Lee
GodSpeed,
Lee
The.car MUST be a 2005+
The ecu didn't support it in earlier versions...you can't get the right flashes for the earlier cars...
The 2005 ecu DID CHANGE...HAD an extra sensor added, and the maps, and adaptations the tuners could do to it were different...
If the car if before a 2905 refresh...I'd skip the attempt and just do vent guages or make pods for next to the windows....
Good luck...if you find s junked car, you can get the parts with the extra wiring you need....
Try to mount a tablet and an odb2 wireless transmitter?
The general approach is to mirror a phone screen on the Nav. You need to get a video signal from the phone, and then there are aftermarket adapters to display an video signal on the Nav screen.
question about retrofit nav to chrono
Hey Zippy from reading through a bunch of threads on this topic, you seem very knowledgable and I was wondering if you could help me out. I'm looking at purchasing an 06 JCW and pretty much the ONLY negative is it has the NAV option. I much prefer the chrono look or just the regular non_chrono look. If the car is a after the build date you mention below, is it possible to swap the NAV unit out for a chrono pack? It sounds like there used to be an official retrofit kit but that is no longer avail? Any advice you can give me would be great.
R50/53 Adding a Chrono Pack to R53
SmurfNinja
14
Dec 4, 2018 10:13 PM
InnocentiMini
Oct 12, 2018 06:10 AM
PelicanParts.com
Apr 26, 2016 12:19 PM
PelicanParts.com
Tires, Wheels & Brakes
Apr 26, 2016 11:47 AM
