For those of you that have PDC and want the JCW Pro Splitters. You can have your cake and eat it too!
Basically you pull the sensors and holders from the stock bumper cover. Cut through the Butyl that holds it in place (I cleaned of all the butyl when the holder was off the original moulding piece)...Then cut a hole in the Pro Splitter (I used a jigsaw and Dermal (thought it was worth the $50 considering how much the splitters cost).
Then 3M butyl the holders into the new holes and you are there!
I put mine slightly higher in the splitter to stop it interfering with the curves in the new splitter - see the last pic so you understand.
The sensor is slightly higher than before but still works perfectly.
KamGraphica. I did my install a while back so my recollections are likely not 100% accurate. I think that the JCW splitters require some longer clips but you that will be clear once you get into the project. You will be able to buy these from your dealer once you have them off it will be clear to you. I think though you can mainly reuse what you take off. I had to use special hardware as I was adding another splitter underneath.
Hope this helps....basically get the old ones off (you will not need to remove the bumper) and figure it out from there.
One note though - it is easier if the front of the car is raised. I think you need to drop the front edge of the cover under the engine bay where it mounts to the cowling.
I just want to thank for sharing this guide that made me dare to take on a project like this. I think these front splitters makes the front so much nicer.
Here is a guide how to make the swap (for cars without sensors):
