R50/53 2002 R53 Noise Issue
Old May 28, 2016 | 05:45 PM
William Griff's Avatar
William Griff
Hey there guys and gals,
Slight issue here,
Everytime I reach 2000 rpm my car makes a weird noise almost as of metal is touching, rubbing, or smacking.it happens in every gear not just first. It happens only in acceleration and never in deceleration. It happens only when the has all four wheels on the ground as well. I put the car on jack stands and gave it a go whilst lifted and the carcar made no noise at any rpm.
Has anyone occured a problem such as this?
Or have any insight?
Old May 28, 2016 | 07:06 PM
David.R53's Avatar
David.R53
Ooh. A good who-done-it.
Could you clarify if the noise happens at low rpms up to 2000 or just at a specific rpm (close to 2000)?
Does the engine being warmed up or cold matter?
What tranny do you have? Any mods? Any recent work?
Old May 28, 2016 | 07:09 PM
David.R53's Avatar
David.R53
For your jack stand test, did you put the car in gear so it was spinning the wheels?
What happens when you rev the engine in neutral with all 4 wheels on the ground?
Old May 28, 2016 | 07:33 PM
ZippyNH's Avatar
ZippyNH
Look at your engine mounts....
Free spinning tires on a jack shouldn't make the motor move with bad mounts...
But the tq when moving might...
ALSO WONDERING if the weights on the dual mass flywheel are loose...like the springs get unstuck, like the Chewbacca, but one broke...giving you the sound....longer shot..A WAG..
How many miles on the car? Any mods?
Last edited by ZippyNH; May 29, 2016 at 05:47 AM. Reason: Hate auto correct...makes me look like a nut!!
Old May 28, 2016 | 07:42 PM
David.R53's Avatar
David.R53
I was thinking engine mounts, too. Causing something to rub on one of the front axles? Should leave a mark on the axle.
Old May 29, 2016 | 02:59 PM
William Griff
It happens only at 2k rpm. Warm or cold same problem. And I have a 6spd mt. Alta cold air and heat shield are the only mods.
Old May 29, 2016 | 03:00 PM
William Griff
Car was in gear, went through 1st through 3rd. No noise. And no noise when Rev with all 4 on the ground.
Old May 31, 2016 | 07:53 AM
Check those engine mounts upper and lower first. Press on the engine on the passenger side, do you have allot of movement?
https://www.northamericanmotoring.co...mount-bad.html
https://www.northamericanmotoring.co...ine-mount.html
Old May 31, 2016 | 08:12 AM
nkfry's Avatar
nkfry
Slight issue here,
How many miles are on the car?
Is the crank pulley failing/failed?
Is it a "tinny metallic" sound or a metallic thud?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
DaGriz
May 14, 2016 03:56 PM
fridayxiii
Suspension
May 1, 2016 05:01 AM
mini-dad
Apr 6, 2016 06:57 PM
maxedmini
R55 :: Clubman Talk (2008+)
Mar 21, 2016 08:42 AM
Ryan Caballo
Mar 16, 2016 04:57 AM
