All Season Tires for 2013 Mini
Hey all, I currently have the Hankook Optimo H426 P175/65R15 tires, 60k mile prorated, and I only have 27k on them and they already need to be replaced. I do mostly highway driving with nothing crazy. I have the 2013 Cooper Hardtop.
Any recommendations on all season tires that will not wear so quickly?
http://www.tirerack.com/tires/tires....omCompare1=yes
Compare the ratings for those tires to the Optima 426:
Make sure you rotate for maximum mileage no matter which tire you buy.
for 2008 r56 hardtop..
would you recommend this all season? or stick to the above mentioned by hsautocrosser?
http://www.tirerack.com/tires/tires....&affiliate=FH8
thanks
thanks
For longer wearing tires and comfortable ride you can try Grand Touring All Season tire class and you don't need to keep the 175/65-15 OEM tire size.
You can use 195/60-15 which fits the MINI 15" wheel fine and will give you a larger tire selection to choose from.
see
http://www.tirerack.com/tires/survey...earDiameter=17
Of these the premium riding tire is the Michelin Premier A/S for $122 each.
Good handling dry or wet, OK in light snow or cold, comfortable and longer wearing (640 treadwear).
What is your budget?
If you must use 175/65-15 or are on a limited budget then-
Goodyear AltiMax RT43 for $68 each
Look at the tires that got worn out early, were only the front tire edges worn badly? If so then you would be better off rotating tires front to rear every 4000 miles since front tires wear out twice as fast as the rears if you don't rotate them.
175/65 R15
what is 84h? thats on the current tire.
I'm in metro NYC area.. every year is now a gamble.. past year, not much snow. year before, so much, they asked peeps to stay off roads till plowed! so, not much snow then as well
So, I would say NOT deep snow.. roads are plowed...
Thanks again for your help!
175/65 R15
So, I would say NOT deep snow.. roads are plowed...Thanks again for your help!
Smaller diameter wheels rotate more per mile than larger diameter wheels therefore the rubber on the tire is subjected to more friction (wear) . Tire rotation (regardless of what MINI says) will make your itty bitty wheels/tires last longer. Double deuces on a donk will out roll yours by miles.
ISAMIN
ISAMIN
Smaller diameter wheels don't rotate independently of the tires fitted on them. 15-16-17" hardtop OEM tire diameters usually vary from 24.0 to 24.6". For reference, worn out tires are typically 0.5" smaller than new.
ISAMIN
ISAMIN
Wheel diameters are 15", 16" or 17" and will fit various tire sizes
Tire diameters are based on the exact tire size such as 195/55-16 or 205/45-17 which give you OEM tire diameters. Tire diameters can affect the number of tire rotations per mile.
I put Bridgestone Driveguard runflats 195/60-15 on my 12 Justa replacing the stock Contis. Have been very happy after @8K so far and much better in wet than the stock tires. Ride is as good as the stock 175/65-15 and better than the Dunlop wintersport 195/65-16 I use in winter (from my 11 convertible). I wont be putting much snow time on these but they are supposed to be all season.
