R50/53 Code help
Old May 25, 2016 | 11:02 PM
mbronsell's Avatar
mbronsell
Code help
Have managed to get a code from the Engine ECU for my Engine light Limp mode
issue
P1570
I need pointers please to what to look for
All electrical plugs look clean and are plugged in usually on a cold start everthing is fine its only when the engine warms up that the engine lamp EML lamp and limp mode engages
Engine starts first turn of key runs smooth even when all lights and limp are on
Can get a lot of information off Delphi software but dont have a set of figures to work from
for example it will give outputs from pre and after CATS
Accelerator
Air mass
lots more but useless if you don't know what your looking for
Old May 26, 2016 | 02:48 AM
Anakist's Avatar
Anakist
Took me about 1min to find an answer on google.
Engine control module (ECM), sensor supply circuit A - low output.
What you do with the info is up to you, but I recommend google.
If you have already found this out, put it in your post so we know you don't just want us to do your homework for you.
James
Old May 26, 2016 | 06:22 AM
Supply A Low Output. P1571. yes.
They also pulled a P1570 with the delphi:
https://www.northamericanmotoring.co...-confused.html
Old May 26, 2016 | 11:51 AM
mbronsell's Avatar
mbronsell
James
To mean an answer would be front left ABS sensor or something specific
because in other control units the codes are quite specific
yes i did google it and got the same answer as you but what does that mean?
it must mean something because they created a code for it
And that explanation of that code is what will point me/ you where to start investigating
Old May 26, 2016 | 05:00 PM
Anakist's Avatar
Anakist
Yep I kept googling after I posted that and hit the wall. I couldn't find anything else. Are you near anyone who can hook up INPA or a specific BMW tool?
James
Old May 26, 2016 | 06:55 PM
David.R53's Avatar
David.R53
According to Bentley manual, P1570 is the ECM internal 5-volt voltage is low (Below 4.2 volts). Consider a failure within the ECM or the power and grounds to the ECM.
Old May 26, 2016 | 07:00 PM
David.R53's Avatar
David.R53
Can't tell why someone posted P1571, but it's similar - ECM internal 5 volt is high ( over 5.8 volts)
Old May 27, 2016 | 01:37 PM
mbronsell's Avatar
mbronsell
Thank you for information
this car is old now 14 years they just don't look it so will be worth putting a meter on various leads and grounds
Old May 27, 2016 | 01:40 PM
mbronsell's Avatar
mbronsell
Bought that software just having mega issues just trying to download it
so easy to waste a whole day on a computer and still get no where concrete
lets just say things get lost in translation
Old Jun 5, 2016 | 04:16 PM
HaveATank's Avatar
HaveATank
What software did you get. I got the software David Suggested and had a little problem with setting IP ect, but i was able to make it work. Purchase a cheap computer after testing it on an old dell with XP, since i couldn't run it in a VM since some of the software run on VMs. Now it the learning process beginnings.
Old Aug 20, 2016 | 03:28 PM
mbronsell's Avatar
mbronsell
Finally sorted the car
Brake issues as you guys suggested ABS sensors
Problem had 2 fitted by mechanic who filed the sensor body rather than clean the holes
sorted by 2 more new sensors and fitted them myself
All engine problems cured by cutting off earth cable and soldering on new ring
earth location ns front strut
Autotragic
Apr 26, 2016 05:22 PM
mini-dad
Apr 6, 2016 06:57 PM
TrackToys
Electrical
Apr 2, 2016 01:22 PM
Rchitct
Mar 28, 2016 05:51 PM
kryall
Mar 21, 2016 08:51 AM
