R50/53 Hella Supertones 02 r53
Old May 12, 2016 | 12:29 PM
slipmagt's Avatar
slipmagt
Im looking to install these with the relay, but with the 2 horns on opposite sides of the car that does make this more difficult.
Can anyone tell me somewhere that the horn wires backtrack where I can splice the relay in easier?
Should I just source a second relay and wire them up right at the mounting locations?
I already own these horns so please do not recommend a different horn.
Old May 12, 2016 | 01:02 PM
Capt_bj's Avatar
Capt_bj
On a GEN1 the horns are already wired with a relay so if you are replacing the stock horns you should be fine. I believe others have gotten these into the stock location - tight but it can be done.
If you are ADDING the Hellas then I have used another relay and just run the relay trigger wire to one of the horns hot lead . . . this is probably overkill tho as the stock setup has the horns on a 15 amp fuse . . . (28 of the in the car panel)
Old May 12, 2016 | 01:14 PM
slipmagt's Avatar
slipmagt
Nope I was going to pull the old ones. I honestly hate the sound of them. Its much too mainstream and it really irks me. I have no issues pulling the bumper off as Ive had it off before.
Old May 12, 2016 | 02:16 PM
Capt_bj's Avatar
Capt_bj
I've got those Hellas on one side of my 79 (wheel well)
and these on the other side
They play a bar of the Colonel Bogey March, popularly known as the theme song from the movie Bridge on the River Kwai (and yes ya'll, I know the details .... I'm simplifying . . . .)
Old May 13, 2016 | 05:31 AM
Some more info here on the hella and air horns, also a guide to get to the old horns.
Most people just rewire the stock plugs to fit the supertones. Or the universal hella horns.
https://www.northamericanmotoring.co...en-a-dump.html
https://www.northamericanmotoring.co...coopers-2.html
Supertone install:
https://www.northamericanmotoring.co...upertones.html
Old May 13, 2016 | 06:19 AM
slipmagt's Avatar
slipmagt
I've looked through both of those threads and they actually aren't helpful at all. The first one is for totally different horns, and the second one if for a totally different car.
Michael Nicely
Aug 1, 2016 10:31 AM
33EJB
Apr 29, 2016 05:19 PM
Apr 20, 2016 04:09 PM
noladude70001
Apr 19, 2016 02:07 PM
navybsn
Apr 19, 2016 05:26 AM
