R50/53 how to check for engine fan running?
Is there a tried and true method for checking to see if the engine fan is running?
About 1,000 miles ago I removed the radiator and fan to replace the CPS o-ring and replace the fan low speed resistor. While it was apart I cleaned everything, flushed the radiator and refilled the system with a 50/50 mix of MINI coolant and distilled water, with a pint of RedLine Water Wetter.
Now the water temp gauge rises to the 12 o'clock position (I have Chrono package) when warming up and moves very little from there. I have even been caught in Atlanta bumper to bumper traffic a couple of times with no problems and very little needle movement.
The thing is, I have not heard the fan run in that time and I would think I would have at least once. Does anyone have any suggestions?
If you want to test the low and high speed fan you can just use the plug on the wire harness that you took apart when you removed the radiator before.
The wire harness has three wires. ground, low and high. Just unplug the connection and use 2 wires and jump to a power source like the battery. You can hear the difference between low and high speed fans.
This test will not prove that the temperature is triggering the fan. Low and high speed fan is triggered by 2 different temp values and I don't recall what they are.
But it sounds like it's working fine. It takes heat to get the high speed cranking.
///Rich
I'm not selling anything, but during my tool review, I found that the Schwaben scan tool can activate the different stages of the fan for your diagnostics. It isn't free, but if you needed an excuse for a really good scan tool... more toys!
https://www.northamericanmotoring.co...eo-review.html
I believe that is normal. That is what my car (also Chrono) did prior to the fan and coolant work and what it does after the work.
PelicanParts.com
Mar 16, 2016 12:37 PM
PelicanParts.com
Mar 15, 2016 03:22 PM
Thanks for the info.
