R50/53 Passenger door lock stopped working?
Old Apr 20, 2016 | 10:30 PM
Stripeknight's Avatar
Stripeknight
I have a 2005 R53 with about 26,000 miles on it, I drove my cooper for the first time today since this weekend and found that the passenger lock will not actuate open or closed when I hit the button on my key...
Any ideas as to how to fix it?
Old Apr 21, 2016 | 12:08 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Will both doors lock/unlock using the toggle on the center console, or just the driver's side?
Check your fuses?
Old Apr 21, 2016 | 04:51 AM
IQRaceworks's Avatar
IQRaceworks
I'm guessing that the door actuator that locks/unlocks your door (located inside of your door) has died on you. Mine died last year.....just haven't got around to buying a new actuator....they are around $100.
Old Apr 22, 2016 | 08:23 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Is it the same when you try to unlock it with the switch on console? If the fuses and everything checks out, you can pull off the door panel and investigate further. We have actuators HERE if needed. Otherwise, might try repairing with this DIY HERE.
888.280.7799 | 6am - 5pm PST
Old Apr 27, 2016 | 06:46 PM
IQRaceworks
I thought about trying to repair mine....but after I spend about 30min getting it out of the door, and messed around with the actuator for about an hour trying to get it apart...I finally gave up. It's rather spend $100 and buy a new one vs. trying to tear one apart, fix it, and get it all back together....and hope it works. Maybe for a year, maybe for a week.
Ironoar
Mar 27, 2020 09:54 AM
David.R53
May 8, 2016 05:45 PM
Old Lotus Guy
Apr 7, 2016 04:36 PM
R53Goodness
Apr 4, 2016 11:11 AM
co0p3r
Mar 28, 2016 07:46 PM
