R52 Question about valve cover
Old Apr 20, 2016 | 08:45 PM
DrSteve's Avatar
DrSteve
New owner of an '07 Cooper S 6 spd. with 36K. Mechanic at a private and respected Mini repair facility spotted a thin oil film on most of the valve cover. He said it now needs (or soon will) a new valve cover and that this is not an uncommon repair on these engines. I assumed it would simply require a new gasket but he is saying it need a whole new cover.
Has anyone experienced this problem and if so what was the fix you did?
Thanks in advance for your help on this.
Old Apr 21, 2016 | 04:10 AM
53ryder's Avatar
53ryder
New Mini owner myself, but old time car guy. The cover would need to be replaced if it has been damaged, cracked or somehow warped. Otherwise a gasket ought to do the trick. Has the mechanic shown you why the cover needs replacing?
Glenn
Old Apr 21, 2016 | 04:59 AM
DrSteve's Avatar
DrSteve
other than pointing to the oil, no, he has not.
Old Apr 21, 2016 | 02:04 PM
Helo, you are in the R52 Gen1 MINI section. You need the R56+ section if if you are talking about the valve cover , it comes with a new gasket : 11127646555
https://www.northamericanmotoring.co...lve-cover.html
Old Apr 21, 2016 | 04:56 PM
05r50's Avatar
05r50
Actually it is quite common to replace the cover when it is leaking. Not sure what all fails, but you can buy the gasket alone, or the cover and a gasket.
I had my gasket replaced and it still leaked. Had the cover replaced to fix it.
Old Apr 21, 2016 | 04:57 PM
DrSteve's Avatar
DrSteve
Thanks for the help folks.
Old Apr 26, 2016 | 11:33 AM
Welcome.
Old Apr 26, 2016 | 11:35 AM
DrSteve's Avatar
DrSteve
Cover and gasket replaced - plugs too. All working well. Thanks again.
Old Apr 26, 2016 | 11:49 AM
Welcome.
Old Apr 26, 2016 | 12:05 PM
ZippyNH's Avatar
ZippyNH
Many gen2 cars have the PCV valve molded into the valve cover....
So if you take it off, you generally replace it....the pcv can get sticky, and cause oil leaks.
daoust
Mar 28, 2016 07:04 PM
Rchitct
Mar 28, 2016 05:51 PM
Sandijs Shifers
Mar 23, 2016 02:13 PM
Mar 23, 2016 09:57 AM
PelicanParts.com
Mar 22, 2016 08:44 AM
