R56 CEL codes after installing AEM Intake
Old Apr 5, 2016 | 05:08 AM
GrayGhost's Avatar
GrayGhost
I installed a AEM intake and my R56 has been consistently throwing P115C and P115D codes. The car will throw these codes while driving, I replaced the BOV from WAY Motors and got a stronger spring from Alta. And that seemed to help a little bit. I also lose boost sometimes when accelerating and experience turbo surge when traveling at highway speeds 70-80mph. I don't want to spend money chasing codes, changing parts that don't need to be replaced. Any guidance would be much appreciated.
Old Apr 5, 2016 | 09:27 AM
GEMSTER's Avatar
GEMSTER
Clean your MAF sensor
Old Apr 5, 2016 | 11:17 PM
GrayGhost's Avatar
GrayGhost
Hey GEMSTER, cleaning the MAF sensor seemed to help a lot although the sensor didn't appear to be dirty. Car is throwing P115C and P115D upon starting. If I clear the code and attempt to restart the car, the car has some troubles initially remaining running (idling). I have to get it some gas so it will remain running. Once I start driving the car it will idle just fine.
Old Apr 5, 2016 | 11:25 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Did you try going back to stock intake.
Old Apr 6, 2016 | 04:35 AM
GrayGhost's Avatar
GrayGhost
Mooch, It started throwing codes shortly after I put the AEM intake on. I have on of those OBD2 reader/scanner so I usually reset the code in the morning before i drive to work.
Old Apr 6, 2016 | 07:39 AM
+1 Try going back to stock first.
Do you have a good code reader , if you have this it will read the stored Unit fault codes.
https://www.northamericanmotoring.co...d-q-and-a.html
You might just have the intake installed and something is not tight on the intake.
Old Apr 6, 2016 | 03:00 PM
GrayGhost's Avatar
GrayGhost
I have the Actron AutoScanner Plus
Old Apr 7, 2016 | 05:49 AM
Had that, does not show all the stored codes, only the live ones and sometimes takes 2-3 times to scan to find anything.
Old Apr 7, 2016 | 09:33 AM
GrayGhost's Avatar
GrayGhost
So I shouldn't clear the codes for a while? The reader said that the most likely fix was new spark plugs and coil packs. I replaced them about a year and a half ago. Would a tune up grade work?
Old Apr 7, 2016 | 10:17 AM
No , there are codes the actron unit can find and other they can't that are unit specific, ( stored codes ). the schwaben scan tool can find them. Otherwise you will be replacing parts till its fixed, but you ca n go the easy route and do the replacement maintenance.
Old Apr 8, 2016 | 10:03 AM
GrayGhost's Avatar
GrayGhost
Thanks I will check the Schwaben out
Old Apr 8, 2016 | 10:24 AM
Welcome.
Old Apr 16, 2016 | 05:36 PM
GrayGhost's Avatar
GrayGhost
It ended up being, the noise maker hose came off. Someone forget to tighten the clamp.
stierzy34
May 24, 2016 07:23 AM
TheBingoBalls
Suspension
18
Mar 22, 2016 10:15 PM
Justin Nemec
Feb 25, 2016 12:43 PM
Emvin15
Feb 24, 2016 03:53 PM
takrdown
Feb 17, 2016 07:33 AM
