Suspension koni fsd noisy shocks
Old Mar 31, 2016 | 06:49 PM
nels415's Avatar
nels415
Hi all,
So I just got koni fsd struts installed on my car with the stock springs, and I'm getting a lot of noise from the rear struts. They are very squeaky. Was something missed during the install? Anyone else have this problem and have been able to resolve it? I also got a new hotchskis 25mm rear sway installed at the same time. So far the ride is much better, it's just that squeaking is a nuisance.
-nels
Old Mar 31, 2016 | 07:05 PM
ZippyNH's Avatar
ZippyNH
Check the sway bar first....they usually have a pack of lube to lube the rubber bushing when you install them....most brands need a relub every couple years. Some brands "kinda" fit, and can rub or clunk....so look closely.
Old Mar 31, 2016 | 08:56 PM
Fly'n Brick's Avatar
Fly'n Brick
+1 on the sway bar bushings, a common complaint.
Old Apr 1, 2016 | 06:31 AM
GAT's Avatar
GAT
+1, sway bar bushings are your culprit
Old Apr 1, 2016 | 07:49 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did the sway bar come with new bushings? Since you just installed the bar, did you use a lot of grease on them? I'd also maybe check the sway bar end links. I've had a loose one before cause a good squeak and another time cause a good clunk from the rear.
888.280.7799 | 6am - 5pm PST
Old Apr 3, 2016 | 08:14 PM
nels415's Avatar
nels415
ok thanks all for the advice. I will have the shop take a look at the rear swaybar. It did come by poly bushings. They may need to grease it up some more.
-nels
Old Apr 4, 2016 | 09:25 AM
ljmattox's Avatar
ljmattox
Looks like you got good advice; fwiw, I had FSDs installed last fall, and no squeaks. Then, or since. Just a vastly improved ride / compliance with road irregularities.
Old Apr 7, 2016 | 06:58 PM
nels415's Avatar
nels415
Yep, you guys were right on the money. Shop said they had to grind down the poly bushings a bit as they were getting binded up onto the swaybar. All is good now. No more squeaking. Thanks all!
NYXF56JCW
Suspension
Apr 5, 2016 11:24 AM
Helix13mini
Mar 11, 2016 12:52 PM
Luis Escalante
Mar 8, 2016 08:38 PM
theinternot
Mar 4, 2016 04:17 PM
Mar 3, 2016 09:05 AM
