R50/53 engine mounts
Old Mar 28, 2016 | 07:23 AM
bneer's Avatar
bneer
engine mounts
Mini began feeling rough. Visually checked engine at idle, was shaking like some mechanical hopper. Wondered if anyone had any parts recommendation. Assuming engine mounts.
Old Mar 28, 2016 | 07:42 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you looking to go for a performance gain (polyurethane) or keep it stock? If poly, go with Powerflex here: http://www.pelicanparts.com/catalog/...pg4.htm#item22. Or OE replacements here: http://www.pelicanparts.com/catalog/..._pg3.htm#item8.
888.280.7799 | 6am - 5pm PST
Old Mar 28, 2016 | 11:14 PM
GPToyz's Avatar
GPToyz
do yourself a favor if you are going to take care of this; do it once and do it right and don't ever deal with it ever again lol :D
TSW Solid Engine Mount
Super Pro Upper Motor Mount Insert
OEM upper motor mount
Super Pro Lower Motor Mount Insert
OEM lower motor mount
Super Pro Transmission Mount Insert
Oem transmission mount
Old Mar 29, 2016 | 05:33 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Originally Posted by bneer
Visually checked engine at idle, was shaking like some mechanical hopper... Assuming engine mounts.
Did you visually check the engine mounts, both above and below? Was there an excessive amount of play there -- at the engine mounts? If the center bolts that go through the rubber bushings in the mounts (both top & bottom) are rattling about, then it very well could be the mounts. If the assembly looks tight, you may have bigger problems.
Can you post a video?
Old Mar 29, 2016 | 06:47 AM
bneer's Avatar
bneer
mini mounts
Well I am now filled with dred. What are the bigger problems.
Old Mar 29, 2016 | 07:27 AM
IQRaceworks's Avatar
IQRaceworks
Just buy a new set of poly engine mounts, and be done with it
Old Mar 29, 2016 | 07:34 AM
PelicanParts.com
Vendor
If you visually inspected you'll be able to tell if it's a bad mount so look it over again. In the later MINIs (2004 on; which is what you have), they use a liquid filled engine mount on the passenger side that can leak and eventually collapse. Look it over carefully.
Old Mar 29, 2016 | 12:11 PM
bneer's Avatar
bneer
mounts
Front top mount seems to be fraying around middle. Have ordered replacement, engine vibrates at idle, runs smooth as glass on the road.
Old Mar 29, 2016 | 12:30 PM
PelicanParts.com
Vendor
If you're replacing the front passenger side mount there is a 'one-time use torque-to-yield ' torx bolt and is recommended to be replaced with a new one for when you install the new mount. http://www.pelicanparts.com/cgi-bin/...-6-766-753-M26. Info here with pictures for reference.
Apr 11, 2017 05:45 AM
adolphrettmer
Mar 7, 2016 07:28 PM
daltonnnn
Mar 4, 2016 04:18 PM
ultrahuck
Mar 3, 2016 05:37 AM
Mar 1, 2016 04:44 PM
