R56 Sun Roof Noise
Old Mar 28, 2016 | 05:17 AM
mini4mo's Avatar
mini4mo
Sun Roof Noise
So just like the title says we have a noise.
It can be heard once your traveling about 50 mph +.
Is there an easy way to adjust or should we take it to the dealer and hope the extended warranty covers it?
Old Mar 28, 2016 | 09:16 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you hearing it when the sunroof is closed? There was a TSB for it I believe, so it might be worth bringing it up to your dealer. Check out this thread here: https://www.northamericanmotoring.co...d-sunroof.html
888.280.7799 | 6am - 5pm PST
Old Mar 29, 2016 | 05:16 AM
mini4mo's Avatar
mini4mo
Yes.
From outside,I can push the front of the front panel down about 3/32"-1/8" when it is closed.
That thread is from 2008,any newer issues?
Old Mar 29, 2016 | 07:45 AM
PelicanParts.com
Vendor
Originally Posted by mini4mo
Yes.
It's a common complaint with many threads. Most of what is said is alignment or bad seal. That one in particular gives you good info so I'd give your dealer a call to see what they say first. Otherwise, you could try adjusting it to see if it helps.
https://www.northamericanmotoring.co...ind-noise.html
https://www.northamericanmotoring.co...-closed-2.html
Old Mar 29, 2016 | 08:19 PM
mini4mo's Avatar
mini4mo
Thanks Pelican
Old Mar 30, 2016 | 08:03 AM
PelicanParts.com
Vendor
Thanks Pelican
You're welcome. Be sure to report back with what they say.
James_in_PDX
Navigation and Audio
Apr 9, 2017 03:05 PM
Thanatoz
Mar 29, 2016 08:58 AM
Rchitct
Mar 28, 2016 05:51 PM
brawsie
Mar 27, 2016 12:25 PM
matt12mcs
Mar 18, 2016 07:11 AM
