Navigation & Audio Hard Drive type
Old Mar 23, 2016 | 08:26 AM
MES11's Avatar
MES11
Hard Drive type
Does anyone know what type of hard drive in the new Mini? Is it integrated or can it be swapped with a faster or larger drive?
Old Mar 23, 2016 | 10:02 AM
anotherminiinthegarage's Avatar
Well, you would have to reload - from somewhere - Nav, music, owner's manual, etc
Old Mar 23, 2016 | 10:01 PM
pppdxx's Avatar
pppdxx
There is a thread on bmw forums about swapping out the HD. Looks really difficult.
Old Mar 24, 2016 | 05:16 AM
MES11's Avatar
MES11
Do you have a link?
Old Mar 24, 2016 | 03:11 PM
siriuszero's Avatar
siriuszero
It's a 200GB hard drive and it is next to impossible to replace. Not just any HD will work, they have to meet a certain spec and have to be "signed" - the car will check for it. There's one guy on Bimmerfest who's undertaken a swap for funsies, but it is VERY involved and I don't think he was successful. Definitely not an easy project even for the veteran modder with a comp sci background.
EDIT: I should mention also for people unfamiliar, that the hard drive is only found on the Connected XL unit. It store nav data, system data and has 20GB allocated for music storage.
Old Mar 25, 2016 | 05:18 AM
MES11's Avatar
MES11
Thanks for the info. I wasn't planning on swapping it out. I was just curious. I would like to know if it is an SSD or not though.
Old Mar 25, 2016 | 12:07 PM
siriuszero's Avatar
siriuszero
Nope. Mechanical automotive grade hard drive.
Here's the thread on Bimmerfest if you're interested:
http://www.bimmerfest.com/forums/sho...d.php?t=787230
Old Mar 25, 2016 | 12:41 PM
MES11's Avatar
MES11
Thanks for the link seriuszero. That had some great info.
Old Apr 19, 2016 | 12:25 AM
icep's Avatar
icep
@MES11: I bought an additional USB port, modified it and connected to a active USB Hub. Then I have installed an external SSD. The front USB still works together with the SSD.
Old Apr 19, 2016 | 04:18 AM
hammerhands's Avatar
hammerhands
icep, I'm having trouble believing what I'm seeing.
Is there a thread somewhere?
That additional USB port is in your glovebox? Is it a MINI part?
Do you have nav? I was not able to get anything additional connected with a hub and my non-nav radio.
Old Apr 19, 2016 | 09:09 AM
icep's Avatar
icep
@hammerhands: the usb port in the glove box and the hub are 3rd party parts. I've connected the Hub to the front USB port and the modified front panel usb and SSD to the hub. I have snap-in adapter too and all works simultaneously.
Old Apr 24, 2016 | 02:14 PM
siriuszero's Avatar
siriuszero
Wait, am I the only one to notice that you put the JCW exhaust controller in your CLA port? That is an excellent idea for placement!
Old Apr 25, 2016 | 01:28 AM
icep's Avatar
icep
Yeah, that's right. You have seen well
Old May 3, 2016 | 06:54 AM
dbdecker's Avatar
dbdecker
oh that is good, very good sir!
You should make and sell that as an accessory!
Old May 11, 2016 | 02:40 AM
JohnWB's Avatar
JohnWB
Does the hub have more than one usb connection or is it just an extension of the existing one.
I tried with a hub a while ago, but could only get one input at a time to work.
Old May 16, 2016 | 09:36 AM
icep's Avatar
icep
The hub has 5 ports...
Old May 21, 2016 | 03:56 AM
JohnWB's Avatar
JohnWB
Could you let me know the make and model please
Old May 30, 2016 | 03:55 PM
icep's Avatar
icep
Sorry for my late reply...
EasyAcc® Superspeed USB 3.0 4 Port Hub Bus Powered und Self Powered 2 in 1 Hub mit 1 Meter USB Datenkabel für Mac,iMac,MacBook Pro Air,Ultrabooks,Microsoft Surface RT,Laptops,Raspberry pi,drucker,etc;Schwarz https://www.amazon.de/dp/B00ICZL3KG/..._xpmtxbZ56HP47
ultrahuck
Mar 3, 2016 05:37 AM
Mar 2, 2016 11:35 AM
Mar 2, 2016 11:22 AM
Kevin@Integral Audio
Feb 28, 2016 02:26 PM
Feb 22, 2016 02:54 PM
