Mini Cooper Stage 5 Performance Turbo Kit R56 2011-03/2012
Part No: G2NMK2606
SALE Price $4260.00
Was: $4485.85
You save: $225.85
This is a Special Priced Item
This Item has a $250.00 core charge.
Description
The Stage 5 Performance Upgrade kit to transform you MINI! This kit blends the racing performance experience of Mini Mania with the demands of the enthusiastic MINI driver. Designed for the Track oriented MINI, this kit includes components that are NOT STREET LEGAL, and will trigger the Check Engine Light from the O2 sensors (unless you add provisions to cancel the error).
Fits the following Cooper S models with the N18 Engine:
2011-03/2012 R56 MINI Cooper S Hardtop
The Kits are different depending on the production date of your R56 Hardtop. There are slight differences with the Intake Kits and the Turbo. Select accordingly.
Kits include:
- K03 Extreme 45 Turbo
- High Capacity Intercooler
- 3-inch Downpipe
- Quicksilver Performance Exhaust
- NM Engineering Cold Air Intake
- NM Engineering Turbo Outlet Pipe
- NM Engineering Intake Charge Pipe
The Hi-Flow Performance exhaust system from Quicksilver provides a gain in horsepower combined with the right amount of aggressive tones consistent with the performance image of the MINI Cooper S. The Hi-Flow Induction system with their free flowing re-usable air filter allows the engine to develop more horsepower while providing superior protection against dirt and debris, extending the engine life. The Hi-Flow Charge Pipe increases flow by eliminating the OEM sound chamber and increasing pipe diameter over stock. The Turbo Outlet Pipe increases flow by eliminating the intake muffler. The 3 inch Hi-Flo™ DE-CATTED Downpipe helps to minimize the backpressure and improves the Turbo's efficiency. High Capacity Intercooler works to keep the intake air temperatures cooler for maximum performance.
The Turbocharger requires a Core Charge. This Core Charge is refunded when your used 'rebuildable' core is sent in. Different models and damages may reduce the amount of Core Charge Refund.
05-09-2017 12:35 PM
tlmease
01-20-2016 02:58 PM
01-19-2016 11:38 AM
01-18-2016 10:38 AM
Suspension Products
01-13-2016 12:31 PM
