R56 Service Light...Car On Lift Symbol
Old Mar 21, 2016 | 05:14 AM
mini4mo's Avatar
mini4mo
My wife's 2012 S shows a service message upon start up.
I scrolled thru the menu and all the items say "OK" except inspection.
What is this and how to clear?
Thanks.
Old Mar 21, 2016 | 08:15 AM
Its the CBS , condition based service , what is your mileage? Dont turn it off or reset it until you have inspected or done it,.
Old Mar 21, 2016 | 08:16 PM
mini4mo's Avatar
mini4mo
61,000 -63,000 miles,cant remember!
What is a condition based service?
This is what i found on the Mini site....(all said ok on the screen).
About Condition Based Service (CBS)
Brake pad wear indicator
Service intervals
Next engine oil change
Next brake fluid change
Old Mar 22, 2016 | 08:19 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Condition based service (CBS) is the system MINI created to manage regular service intervals and maintenance items. Service intervals and maintenance items are no longer services solely based on mileage or time, but now a combination of items. CBS utilizes sensors, vehicle driving conditions, and time to determine the service intervals. We have an article on our site under MINI > R56 articles > Basics & Essentials > Condition Based Service Explained, that goes over each one in detail if you want to learn more about it.
888.280.7799 | 6am - 5pm PST
Old Mar 22, 2016 | 09:49 AM
Kimolaoha's Avatar
Kimolaoha
Thanks.
Estimated (not actual) Brake Pad Wear.
Quoting Capt bj from June 2014 - https://www.northamericanmotoring.co...l#post3951674:
there are two brake wear systems
One is a miles counter, similar to the oil change one, by monitoring certain engine parameters it guesses your brake wear. When my counter went off, I checked my pads, saw plenty of pad left so reset the counter, which can be done thru the OBC and the stalk button.
The other is the brake wear sensor. When the sensor trips the sensor has been "used" and must be replaced to resent this part of the system. The sensor trips by wearing down due to contact with the rotor until a wire loop in the sensor breaks creating an open circuit. So if you try to reset a brake warning and CAN'T, I'll bet you a donut one of your sensors has tripped.
If it's the former, my experience is that the car-on-lift cycles about every 30K miles or so, so your mileage may indicate a second cycle through the CBC. If, as Pelican suggests, you have verified brake condition, then the symbol can be cleared via the OBC and stalk button. Here's one approach, but a search will divine others:
Old Mar 23, 2016 | 04:33 AM
mini4mo's Avatar
mini4mo
OK thanks.
Rock944t
Jul 14, 2016 08:34 AM
KevinR
Apr 2, 2016 08:31 AM
CharlesMeade
Mar 29, 2016 09:57 AM
1004ron
Mar 22, 2016 09:39 AM
1004ron
Mar 21, 2016 10:14 AM
